tranny line problem
Old Feb 23, 2004 | 10:24 PM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
tranny line problem
I just put my Pro built tranny in and i have a tranny line leak. Any one have these problems?? there on tight and can't get them to stop. Any ideas. How can i fix it. thanks
Old Feb 24, 2004 | 05:48 AM
ede's Avatar
ede
it's a flared line, should be no way it leaks if you have a good flare and tighten the nut. check the flare on the nut and the trans fitting.
Old Feb 24, 2004 | 06:13 AM
Car: 1992 Camaro RS
Ya i knew that. thats way i tough it was wierd. someone told me it could also be the fittings coming out of the tranny? How can i fix it?? new lines?? anyone make steel braide line for that?? thanks again
Old Feb 24, 2004 | 07:29 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
I've been there
I've been there. After a radiator replacement on a 82 z28 indy 500, I managed to strip out the threads on one of the lines. I ended up getting new lines from a junkyard. It really is a pain, Unless you have them in exactly straight it'll seem to be tight, but you can get a drip (or in my case, Noah's Flood of tranny fluid).
Make sure you use the flare wrench, it helps
Infested
May 22, 2018 11:56 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
hokis
Aug 9, 2015 03:57 PM
