Pulling Bearings?
Old Feb 28, 2004 | 05:51 AM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Pulling Bearings?
what is the easiest and best way to pull off the bears of my posi carrier and my pinion gear with a bearing puller? also what is a good weight for my SLP posi? does it need Limited slip additive?
Old Feb 28, 2004 | 06:44 AM
ede's Avatar
ede
for the carreir bearings i use a puller with a long screw and puller center in the center part of the carrier. pinion bearings i use a bearing seperator and a press but a puller would work instead of a press. by weight you mean oil? i run M1 or amsoil synthetic something like 75w-90. any and all clutch type posi units need posi additive and gm makes the only one i'd use.
Old Feb 28, 2004 | 08:27 AM
92MaroRS's Avatar
its the Zexel-Torsion posi. any way to do it without a puller as i dont have access to one.
Old Feb 28, 2004 | 06:36 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Nope. Press, puller, or otherwise machinery will be necessary. Or take it to a shoppe to have it done.
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
86IROC112
Aug 31, 2015 07:00 AM
anesthes
Aug 26, 2015 01:37 PM
red90IROCls1
Aug 25, 2015 06:56 AM
rsrmoore
Aug 7, 2015 08:44 PM
