Can i use an 84 700R-4 in my 89
Old Mar 10, 2004 | 08:26 AM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
The trans is from an 84 trans am. Can i use it in my 89 camaro RS?
Old Mar 10, 2004 | 11:08 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
You can, but I don't know that you want to. The 700R4s were significantly upgraded in '87. The earlier units use fewer 3/4 clutches, lack an auxiliary valve body, and are generally weaker than the post '87 counterparts.
Unless you are getting the '84 trans real cheap, and/or just need to get the car back on the road, I would search for an '87 up trans as a replacement.
Old Mar 10, 2004 | 11:24 AM
89305RS's Avatar
Ok thanks TKO. Ill do that.
89 Iroc Z
Jun 14, 2003 12:24 AM
89 Iroc Z
Dec 26, 2001 12:29 AM
FstBrd6point3
Car Audio
Dec 4, 2001 11:31 PM
89 Iroc Z
Dec 2, 2001 07:14 PM
FstBrd6point3
Car Audio
Nov 29, 2001 07:24 AM
