Clear Diff Cover?
Old Mar 9, 2004 | 03:50 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
Clear Diff Cover?
Think its a cool idea to get one?
Old Mar 9, 2004 | 04:37 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Wow, that's pretty niffty. How much does something like that run?
Old Mar 9, 2004 | 05:14 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
wow thats so kool!!!!! but chrome still looke better in my taste. but still that clear one is really kool! fist time i ever seen one before.
Old Mar 9, 2004 | 06:56 PM
bes217's Avatar
Wouldn't you lose a lot of strength by putting a flimsy piece of plastic on your rear end like that.
Old Mar 9, 2004 | 07:13 PM
llvll4l2c91350's Avatar
exactly what i was thinking. i would buy this it looks cool but not if it's gonna blow out in time.
Old Mar 9, 2004 | 07:18 PM
HamSpiced's Avatar
i did a google search and people have said that its supposed to be stronger then stock.... its made out of some prograde stuff that they use for bullet proof glass...
its in summit the company i believe is called Clear Cover...
Old Mar 9, 2004 | 10:30 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
a flimsy piece of plastic isn't any worse than a stamped steel cover. The covers are normally not a stressed member. Now paint all the gears different colors and put some neon inside!
I just threw up on myself
Old Mar 9, 2004 | 11:26 PM
bes217's Avatar
The covers are a stressed member or else they would not sell reinforced covers for these rear ends. If you read the tech article on building a better 10-bolt one of the things is a reinforced cover.
Old Mar 10, 2004 | 12:40 AM
25THRSS's Avatar
mainly for the bearing cap supports
Old Mar 10, 2004 | 01:05 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
its in summit for 139.95 part number is TRD-8402
Old Mar 10, 2004 | 08:29 AM
MdFormula350's Avatar
that is pretty slick.
how about some clear hoods, doors, and lets use metal for the windows j/k
a clear tranny pan might be cool also
Old Mar 10, 2004 | 08:46 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
nah, youd just get to look at a transmission filter.
Old Mar 10, 2004 | 09:00 AM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
NOW i think a clear oil pan would be awesome seeing the motor at 4g RPM
Old Mar 10, 2004 | 10:35 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
what about head disapation, i can't imagine a plastic of anysort would be good for disapating heat. maybe if my car was a show car... i'll stick with an alum. gridle though.
Old Mar 10, 2004 | 10:45 AM
HamSpiced's Avatar
Im all for a clear tranny pan..... JUST AS LONG AS IT HAS A DRAIN PLUG!!!!
Old Mar 10, 2004 | 11:44 AM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
The stock cover is not a stressed member. The point is by using the plastic cover in place of the stock cover you are not compromising the strength of the differential. using a reinforced cover is an enhancement, not a requirement.
They make clear valve covers at one time but ran into sealing problems from heat warpage. if the used a metal clamping flange it would have been better.
how about flouresent rocker arms and a black light? then throw a little of that dye they use to find leaks in the oil! We could all eat some acid and watch it all night. We'll see ***.
gta892000
Sep 16, 2015 12:37 AM
Nick McCardle
Sep 10, 2015 08:36 PM
carattini
Sep 10, 2015 07:46 AM
rudolphschenker
Sep 4, 2015 02:41 AM
