Transmission cooler questions
Old Mar 13, 2004 | 03:06 PM
vwdave's Avatar
Alright, I am getting a Pro-Built Street/Strip kit from Dana (Awesome guy.) I am also adding Motul Synthetic ATF too. Stuff is expensive, so I dont want to waste it.
I want to get this cooler Click Me, plz?
1. Will that biatch fit?
2. I want to run braided lines. So, how should I route the lines? In>cooler>back to Radiator or Radiator>cooler>Transmission.
Whichever way, I will need some fittings for the braided stuff. The cooler uses 3/8" Pipe Thread. My stock lines use Flare IIRC.
I guess we will answer the first two before we move on with line fittings and stuff.
Old Mar 13, 2004 | 03:50 PM
383 rocket bird's Avatar
If you don't have ac it should fit in front of the radiator with no problem. You should always mount the cooler in line after the radiator becaue if not then you are cooling the fluid with the cooler and then heating it up when it goes through the radiator. -John
Old Mar 13, 2004 | 04:19 PM
vwdave's Avatar
I do have AC and plan on keeping it.
At least now I know what fittings I am gonna need.
BTW, I am going to try to custom fab up some brackets. So it does look halfway decent.
Cleotiz
Jan 6, 2018 08:56 PM
Dialed_In
Aug 20, 2015 01:45 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
