turbo 350 in 87 z
turbo 350 in 87 z
This my first camaro project and what all is needed to put a 350 tranny in my 87 does the crossmember line up? the rest realy does not matter becuse it will be an aftermarket shifter and cable.
Car: 4
Engine: 6
Transmission: 5
The crossmember does not line up.
The main thing you'll need to conquer will be the torque arm mount. You CAN'T just leave teh torque arm off, as you will find out (probably the hard way) if you try it.
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
is this a strip car or will there be a lot of street driving? i would keep the 700 in there if you are street driving. cant beat a built 700. a few companies offer aftermarket built 700s for any power rate. the max ive seen one take is 685 at the crank
This will be A strip car for the most part I would say it might see the street once a month or so I was thinking the 350 becuse of the readyness of parts and the cheepness I have built a 383 11to1 with dart sports man II heads 250 nitrios. I'v striped the car of about every thing not needed I'm hoping for about 2500 lbs. it should be fun.
Car: 86 Camaro
well 700s are plentiful in parts. i see more for the 700s then anything, but maybe thats because im looking for 700s and not anything else. if its gonna be strip then go with the 350 i guess. im a 700r4 kinda guy
how much can a 350 handle anyhow?
how much can a 350 handle anyhow? Trending Topics
Car: 86 Camaro
hell, i dont know lol. i dont know a lot about stock ratios and durations and things, i just like putting in aftermarket stuff. you can always have one built to your needs. try www.700r4.com or www.camarotransmissions.com they both offer trannys that can handle 600+ TQ and HP and they list the ratio of each gear below the tranny. 700r4.com offers 4 or 5 stages of trannys so you dont have to get something thats overkill and save some money
Car: 84 Camaro
Engine: v6 to v8 swap 357ci chevy
Transmission: TCI Turbo 350
B&M sells a changeover kit,also Hurst sells 350 or 400 changeover kit check Jegs or Summit.I went 350 because it was cheaper.
Eric-86sc
Aug 24, 2015 09:01 PM
