Bleeding uninstalled slave cylinder??
Old Mar 16, 2004 | 07:49 PM
airbrushguy's Avatar
I am building a hot rod with a 1988 Camaro T-5 and stock slave cylinder setup, and a non stock Willwwood MC. The slave cylinder is higher than the Master Cylinder(under floor) so I am going to attempt to bleed it off the bellhousing, so I can keep the slave cylinder below the MC. Any advice as to whether this will work or how to best do this??
Old Mar 17, 2004 | 05:11 AM
ede's Avatar
ede
i use a pheniox v12. i've never had much luck bleeding the factory hydrolic set up.
Old Mar 17, 2004 | 10:16 AM
"i use a pheniox v12"....
Where can I get one??
Old Mar 17, 2004 | 10:54 AM
ede's Avatar
ede
i got mine from northern tool, mail order. i think snap on sells then along with several other places.
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
