rear gear?
rear gear?
hey guys i got a few questions for you that you can hopefully help with... alright first im about to go to a junk yard tomorrow and i wanan loog around for a new rear gear... currently i have a 2.73 and with the cam i have its spends to much time in 2nd gear makin no power... with the mods i have in the sig and hopefully headers soon... what gears shouldi be looking for... i thought about 3.73 but im thinkin i might be better off with a 3.42 by the way i do have OD... also i hear all this talk about the stock tachs being off... i was wondering if the berlinetta digital tach was accurate? i mean it seems to be but i owuld have nothing to compare it to.. thanks for any help its appreciated...
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
just as inaccurate as the rest in these cars... as far as gears thats more of an opinion, 3.42's will drop your gas mileage less then the 373's will.. both will give you a huge boost in pickup, obviously the 373's more so than the 342's, 373's will have faster acceleration but less top end, the 342's will have more top end and less accel... its your choice.. I'd look for a posi carrier as well.. as far as locating them in a JY most if not all 5 speed cars had 373's, as far as 3.42's look for an auto.. but its a toss up.. best way to tell what your getting is to pull the dif cover and look
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Originally posted by red85berlinetta
with the cam listed in my sig what do you guys think will keep me in my powerband? the 3.73 or 3.42?
I have 3:73's. When I had them installed, I went from a 2:73 one legger to the locker and the 3:73's. I like it a lot. But the stock LG-4 305 would have done better with the 3:42's or even 3:23's. The 3:73's (and my lead foot) wanted more rpm's than the LG-4 could give. This didn't matter to me as the 355 was going in soon anyway.
If you plan on installing headers soon, I'd go with the 3:73's.
However I am not for certain, but I do not beleive any thirdgens came with 3:73's. I thought they did, but I argued with the parts guy at the dealership about this and he said no. I thought that the 92 aniversary edition had the 6 speed and the 3:73 rear, but I later found out that the car I read about was a GM skunk works car.
So your 3:73's may have to be new setup. Or else you could go with a used 3:42 rear.
many if not all 5 speed cars came with 373's, I know all L69 HO cars did for a fact.
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
yeah there gay... but with that cam profile i have it makes all power up top... so what do u think 3.42 or 3.73 also if i go with 3.42 should i buy the gears or just get a new rear with posi? and if i got the hwole rear assembly how much wouild that be?
Car: '86 Z28
Engine: LB9 (305 TPI)
Transmission: 700R4 w/kit
gotta tell us what kind of tranny you have, plays a huge role in choosing gears.
I'm ashamed in you guys giving advice without knowing what tranny he has.
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I don't see it that way
I would use a 3:73 with a manual or a 700R4. I want to get a manual some day and I will keep my 3:73's.
Car: '86 Z28
ok then, i'de go with 3.42's if its a daily driver. With an extra gear i'de definitly go with 3.73's, but i'de stick with 3.42 since you dont have a 5 speed. I spent a lotta time weighing the pros and cons since im gonna be putting in new gears in the next week or so, decided to go with 3.42's w/my 700R4.
The choice is up to nobody but yourself though, im just giving my 2 cents. Either way you decide to go you'll be very happy getting rid of those 2.73's
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
yea i been doing lots of thinking and have concluded i should just get a new posi rear with 3.42 in it... anyone know how much $$ theese are... and is it hard to switch it?
Transmission: 4L80E/4L80E
You get/keep the engine in the powerband with the proper stall converter.
You get the trap or cruise RPM you want with gears (and tires).
You could have 4.10 gears but if you have a 1500 stall converter and the cam comes in at 2500, it's still going to be a dog off the line (just not as much as it would be with 2.73 gears).
It's a "package" thing.
Car: '86 Z28
Yep, $75.00 for a complete rear end at the U-pull-its around here. I called and asked about the following axle...
10 bolt, 7 1/2in., 3.42's, drum brakes, posi unit...
They told me that they dont give a **** what's in it, any 3rd-gen complete rear-ends are $75 as long as you pull it yourself. And they even said they'de use one of their pickups to help get it outta the yard
So just make a few calls, if you dont have any luck at U-pull-its try an auto wrecking place. The prices will be quite a bit higher though.
BTW - That link that my3rd gen. was refering to...
https://www.thirdgen.org/techbb2/sho...hreadid=231297
thats what they go for around here at the you pull it's.. the local one just over the bridge in PA has a few lines of 3rd gens, I know of 4 that have posi's laying under em, 1 nine bolt 3 10 bolts, assorted gear ratios.. got my complete 5 speed setup from the same place for a total of $135
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
