Which F-Body's come stock with Posi?
Old Mar 24, 2004 | 12:16 AM
JoeJuggalo's Avatar
Car: 1984 Z28/ 1990 Plymouth Laser RS-Turbo
Engine: 1977 Chevy 350
Transmission: 5-speed
I'm probably going to ditch my Turbo Neon project & pick up another Camaro/Firebird.
Thanks, Joe
Old Mar 24, 2004 | 12:30 AM
ChevyCamaro420's Avatar
Car: '86 Z28
Engine: LB9 (305 TPI)
Transmission: 700R4 w/kit
There's pretty much no way to tell by model or year... If it's a HO engine with gear ratio 3.42 or higher, then i believe they were required to have posi though...
Check the RPO codes... G80 is limited slip differential.
Old Mar 24, 2004 | 12:36 AM
JoeJuggalo's Avatar
On the average, how much would it cost to have posi installed (part+labor)? Something able to handle up to 450 crank hp.
I really have no idea.
Old Mar 24, 2004 | 01:16 AM
Car: '86 Z28
I'de say around $400-500 for the unit (Eaton/Auburn...something along those lines), then maybe $100 max for labor.
Don't quote me on that, i'm definitly not an expert.
Old Mar 24, 2004 | 10:51 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
No F-body came stock with a Limited Slip (RPO G80) it was a extra cost options. Required with some other RPO's ,however: no way to tell without the RPO"s on the car.
Old Mar 24, 2004 | 11:08 AM
ede's Avatar
ede
i think all TTAs and all 350 's came with posi, but i don't know for sure. what differance does it make what cars came with it and you wanting posi in your car? you need a posi.
slp is 100
28 spline axle is 250 if you need them
gear set is 200
install kit is 100
labor should be in the range of 3 hours
Old Mar 24, 2004 | 01:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
https://www.thirdgen.org/techbb2/sho...hreadid=230299
I'd also add the support cover, ~$150.
400 HP is the generally accepted max for a 7.5" 10-bolt.
The on-line version of the article leaves out a lot of details, such as cost. The magazine was around $1000.
Old Mar 24, 2004 | 02:26 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
There is allways that rumor about the 4 cylinders that got
3:73 posi stock.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
hectre13
Aug 26, 2015 08:17 AM
