Modified T-5....what can it handle?
Old Apr 2, 2004 | 12:47 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I'm looking at a '91 bird right now with the L03 305TBI in it and the 3.08 open rear with a T-5. Eventually, (next spring/summer if all goes well), I'm planning on dropping a built 350 into it with somewhere around 350hp hopefully. At that time, I would also be installing a new rear with posi and probably 3.27/3.42 gears.
My goal is to see mid 12's with this car eventually. Now, I've read that a stock T-5 couldn't handle this very long... My buddy and I can rebuild the trans using titanium syncros and cobalt-coated shift forks for just the cost of parts. How much power should this be able to hold? My buddy said he thinks probably 10% more than stock, but I was wondering what you guys would think.
Also, what's the difference between the WC T-5 and a standard T-5? Thanks!
Old Apr 2, 2004 | 04:14 AM
ede's Avatar
ede
next to zero if not zero syncos and shift forks aren't the weakest part
Old Apr 2, 2004 | 10:34 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Yeah I heard the casing and the gears will bust when they flex, but mine is doing well. I say just run it and wait and see if something breaks, cause chances are it will be fine as long as there is no traction.
Old Apr 2, 2004 | 03:33 PM
Car: 1997 Corvette
Yeah, I'm not planning on running slicks or DRs any time in the near future
Old Apr 2, 2004 | 04:33 PM
GASGZLR's Avatar
Well I am running DR's this weekend for the first time and I am praying that the T-5 is OK.
Old Apr 2, 2004 | 04:57 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I've got a few years of mid 12 second passes on a T5..
Old Apr 2, 2004 | 10:40 PM
GASGZLR's Avatar
You are starting to make me feel better already I am convinced the T-5 will break
Old Apr 4, 2004 | 11:50 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
Everyone loves to complain about how T5's are weak, but they actually hold up pretty nicely. I personally have been beating the living sh*t out of my T5 for almost 4 years now, and it still shifts great. It has almost 180,00 miles and it's a non WC. I pulled it out of my retired 86 TA and now it's doing duty behind my slightly modded 305 TPI in a 92 Z28. Clutch pops, power shifts, constant flooring, constant downshifting, and I road race the car at least 3 times a year, still no porblem.
I know, some of them just blow up after a slight amount of abuse. But some of them just take a lickin' and keep on tickin'. There are also several companies that offer stronger, upgraded internals and complete built up units. G-force and D&D are the first two that come to mind.
<-- Look, he's even powershifting his T5!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
