Replace converter with tranny rebuild?
Old Apr 2, 2004 | 06:14 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Is it necessary to replace the converter if you rebuild your tranny? My 3-4 clutches are going in my 700 and I'll be rebuilding it later this summer.
The fluid still looks and smells fine.
Old Apr 2, 2004 | 06:27 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It's always a good idea to replace it when you rebuild a transmission. If you have an aftermarket converter that you spent some coin on then check your local trans shops and see if they can flush the converter before you stick it back in.
Old Apr 3, 2004 | 07:34 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
It'd be going in the daily driver formula. So i guess I'll just replace it with a stock one.
Old Apr 3, 2004 | 08:10 AM
ede's Avatar
ede
unless cost really becomes a factor i'd replace it. if cost is a factor i'd have it flushed and tested. draw back is flushing and testing cost will or could go towards the cost of a replacment.
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
hokis
Aug 9, 2015 03:57 PM
