where can i get this 21 tooth driven gear for my t-5??help
Old Apr 5, 2004 | 06:59 PM
redtail2624's Avatar
Car: 88 TA
Engine: 383 Converted LT1 intake
Transmission: TH350 3500 stall
Axle/Gears: 12 bolt 3.73's
I tried the dealer and they cant get it and i have to idea who would have this.I have 3.73's and i am pretty sure its a 7 tooth drive gear its a bluish purple color.Did they make an eight tooth?Anyways i need a 21 tooth driven gear so if anyone has one or knows where i can get one please let me know thanks a lot.
Old Apr 5, 2004 | 10:19 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Are you talking about a ring and pinion??
If so they are mached sets with specific mates. Manufacturers lap in a wear pattern before they send them out, then number them so you wont mismatch parts....
Old Apr 6, 2004 | 07:22 AM
Car: 88 TA
a drive and driven gear for a t-5 is for the speedometer,not rearend gears.
Old Apr 6, 2004 | 11:32 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
GM doesn't make speedo gears for a 3.73 swap. I think you can find them aftermarket but not from the General. I am pretty sure there are only GM speedo gears for the 3.08 and 3.42 gears for the T5.
Old Apr 6, 2004 | 01:39 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Yeah call me crazy but that's why i didn't make the switch to 3.73's. I heard that 3.42's will give almost the same performance but at least your speedo will work.
I just thought of something, didn't some of the old Z28's with an L69 and a T-5 get 3.73's stock from the factory? I know those cars had cable speedos and they read right. The beauty of it is the cable and VSS speedo gears are the same, try looking up gears for a 3.73 equipped L69 83 Z28 with a T-5.
Old Apr 6, 2004 | 02:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You can definitely get them at the dealer. The 3.73/T-5 combo was stock in the HO cars.
I know, because I have one, and I've bought gears for it, a couple of times actually.
SLP has them, but their pricibg is a little bit predatory. There's some other place that sells them, but I can't recall who it is.... if you search this forum for "speedo gears" you'll probably be able to find it.
Old Apr 6, 2004 | 02:27 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Hey good to hear. You learn something new every day. Aren't the SLP calibrators for 3.7 gears or some other odd number?
Aren't you still out of luck when it comes to the electric speedo though?
Old Apr 6, 2004 | 03:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well, look at it this way....
From 3.73 to 3.70 is less than a 1% change.
From 21 teeth to 20 teeth, or 21 teeth to 22 teeth, is just about a 5% change.
There's no gears with a fractional number of teeth in between 20, 21, & 22.
So, will it really matter if the gears are said to be for a 3.70 or a 3.73?
As far as electronic ones, I have no clue; but I do know that there were 85 TAs with electronic speedo and L69/T-5/3.70, so they "ought to" exist. (for whatever good "ought to" does anybody)
Old Apr 6, 2004 | 03:36 PM
GASGZLR's Avatar
Hey shifty don't you remember my whole dilema with the T-5 speedo gears, they are the same part number for both just have to remove the metal shaft from the driven gear and then it fits onto the VSS.
Do a search with my screen name in the trans section and the word speedo I did a write up on this about a month ago.
Old Apr 6, 2004 | 04:13 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yea you are right. I forgot how easy your fix was. I just figured SLP would label that calibration as 3.73. That has thrown me off for years and now it makes sence. I didn't realize that the gear for the 3.73 was not an exact tooth count like most other gears are. The gears that do exist that are near it are actually for a 3.70. Makes sense now.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Formula_88AE
Sep 3, 2015 01:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
