Adjust pivot ball/bleed slave or.......
Old Apr 14, 2004 | 07:01 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
When i rebuilt my tranny i used my buddies bellhousing becasue it was cleaner (nothing wrong with mine)...he had a 86 t-5 wereas mine is a WC....i dont think that matters though...
When i pulled the tranny it worked problem free, and now the clutch wont fully engage as to shift from neutral into gear while the motor is running...If its off then itll go into gear and i can drive it, but i have to "slide" it into first when rolling at 5 mph...when i come to a stop with the clutch fully depressed and the brakes off the car will creep forward...There is also a good inch of play on the top of the pedal before its starts building pressure...
At first i thought that maybe i put the throwout bearing in backwards, but i talked to a few tranny guys and they all said "itll go in either way, but the wrong way will tear up the pressure plate"....
So now im thinking either the pivot ball on his bellhousing wasnt adjusted the same as mine becasue the clutch worked perfect before this..or the CF throwout bearing is in backwards (contrary to what 3 reputable guys told me)....theyu all said it would be VERY noisy and as soon as i started the motor id no it was wrong..
So again
I used a non WC bellhousing on a WC tranny
i used a T/O bearing that worked in a non WC tranny
Maybe his pivot ball wasnt adjusted like mine...and how do u adjust that?..
im sure i can tell yall more about it if specific questions are asked..
Thanks alot guys
Rob
Old Apr 16, 2004 | 06:56 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
you guys dont know or dont care?...
hell a "that sucks man sorry i cant help you" post would be better then nothing
Old Apr 16, 2004 | 08:12 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I don't think there is a difference between the WC and non WC bellhousings. I also don't think there is any adjustment in the stock pivot ball. I don't think the T/O bearing was installed backwards, just improperly. I'd remove the trans and check the way the bearing is installed.
Attached Thumbnails Adjust pivot ball/bleed slave or.......-throwout-fork-right-wrong
Old Apr 17, 2004 | 05:51 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
i was pretty sure about the bell's, and i thought i was sure about being able to adjust the pivot ball....
i look at those pics and i cant relly see whats the difference, assuming there is a difference
Old Apr 18, 2004 | 12:09 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I guess I should have stated the top way is correct. Look closely at the fork tangs and you'll see the difference. On the top pic the tangs are on the outside of the bearing and on the bottom their in the middle in the groove.
Old May 4, 2017 | 08:54 AM
Abubaca's Avatar
Re: Adjust pivot ball/bleed slave or.......
I know this is 13 years old, but I found it while looking for other info, and I "think" there is some wrong info. The little tangs on the fork do NOT go on the outside of the throwout bearing. The tangs go INSIDE.
...just in case someone finds this later.
Old May 8, 2017 | 01:46 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Further just in case
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
