Where to get a 9 bolt cover gasket...
Old Apr 16, 2004 | 09:59 PM
SweetRide45's Avatar
I practically gave up on 9bolt.com
I'm looking here : 9 Bolt Parts but the first pic of the gasket they show doesn't look like any 9 bolt cover gasket.
Does anyone have any info on it...and is that "plug like thing" that comes w/ it the filler plug for the cover?
Thanks for the help!
Old Apr 16, 2004 | 11:15 PM
pskel350's Avatar
last time i checked you could get it at advance auto
Old Apr 16, 2004 | 11:37 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You can get them at Auto Zone, but they usually do not carry them in store stock and have to order them. That "plug like thing" is the pinion seal not a filler plug.
Old Apr 16, 2004 | 11:43 PM
Thanks for the help! I didn't think Autozone and those joints carried the seal...Thought they only had the "make your own" gaskets since no one else carries stuff for the 9 bolt...
Old Apr 16, 2004 | 11:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
They carry them, it will be a FEL-PRO gasket.
Old Apr 16, 2004 | 11:50 PM
Thanks man!!
Old Apr 17, 2004 | 10:23 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Use the "tubular style" gasket. Paper doesn't add anything to the overall picture.
Attached Thumbnails Where to get a 9 bolt cover gasket...-tubular-style-gasket.jpg
Old Apr 24, 2004 | 08:28 PM
Eightyninef's Avatar
I have a 9bolt cover gasket I can sell you.
usually they are special order, and take a while to get.
Old Apr 24, 2004 | 09:48 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Just use RTV sealant, don't bother with a gasket.
Old Apr 24, 2004 | 10:39 PM
I was going to use a gasket, then RTV on top. I don't really like the idea of metal on metal...I'd want some type of "sleeve" inbetween the two (gasket)...I'd think that'd make a more secure/reliable seal, rather than just RTV by itself...That's my logistics of it...
Old Apr 24, 2004 | 10:54 PM
pasky's Avatar
I've been running RTV by itself and so do a lot of people, metal is not on metal, the rtv is inbetween both, make sure you use the black one as it has the most oil resistance.
Old Apr 26, 2004 | 11:51 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Advance: $6
Pep Boys: $11
Same Fel-Pro gasket..
Ed
Old Apr 27, 2004 | 08:24 AM
Thanks! I was thinking of going w/ Autozone...$11 too. Just have to special order it...
Old Apr 29, 2004 | 03:19 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
I know this is a F*&d, but my F150 didn't have a gasket in it. FWIW.
Old Apr 29, 2004 | 03:57 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
RTV works better than a gasket on a rear cover. One tube will the job 3-4 times, plus you will always have one on hand if you keep a tube around. Just use the exact stuff RB has a picture of.
Old Apr 29, 2004 | 06:10 PM
I probably will use a few dabs of RTV...but I don't like the idea of RTV gobbed all around...then, whatever squished out the sides might fall in, and who knows what else...
Old Apr 29, 2004 | 06:55 PM
pasky's Avatar
Your not supposed to gob it on .
Old Apr 29, 2004 | 07:09 PM
Ricktpi's Avatar
Yea, a little goes a long way. All the OEMs, GM, Ford, & Daimler-Chrysler all glue 'em on with RTV.
Old Jun 6, 2004 | 11:43 AM
Spdfrk1990's Avatar
Can you get the rubber fill plug anywhere mine is leaking like hell i wish some1 had a aluminum cover out now. Im rdy to take this thing out and pull the axels for my pbr brakes. Ill be adding royal purple and i dont wanna lose any.
Old Jun 6, 2004 | 09:44 PM
ebmiller88's Avatar
I just sandblasted mine and welded a plug from Moroso on it. I likey!
https://www.thirdgen.org/techbb2/sho...ighlight=cover
Ed
Old Jun 6, 2004 | 09:49 PM
Spdfrk1990's Avatar
Damn good idea where did u get your new cover at? NM u said u sand blasted it anyway did you get the steel or aluminum plug. Cause is it just the cap aluminum cause i dont have nething to weld aluminum.
Old Jun 6, 2004 | 10:37 PM
ebmiller88's Avatar
That's my stock cover, sandblasted and repainted. I used the steel bung as it comes with an aluminum cap. I can do yours for you if you' d like me to.
Ed
Old Jun 7, 2004 | 06:38 AM
Spdfrk1990's Avatar
Ok so you bought the one that says steel and they both come with aluminum caps. I got a welder and a sandblasting cabinet did u just weld it over the hole u didnt cut it to size or nething right.
Old Jun 7, 2004 | 08:28 AM
ebmiller88's Avatar
I TIG welded it to keep it cleaner, but I made no other mods to it...just sandblasted it and welded the bung to it. Be careful not to blow a hole in the cover.
Ed
Old Jun 7, 2004 | 04:32 PM
Spdfrk1990's Avatar
Thanx for your help i should be ok the cover isnt to thin of metal.
Old Jul 8, 2004 | 05:31 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I just ordered the 9-bolt gasket (FelPro) from the local parts house. Took one day to get it in from their warehouse. Cost me like 5 bux and change. Nobody will have them in stock, but most parts houses can get it in a day or two.
You can get a replacement rubber fill plug from GM, it also costs 5 bux and change. I just ordered one from the local Poncho/Buick dealer. I wanted to have a spare on hand in case the one in the diff now gets damaged when I pry it out. When they get old the rubber hardens and they don't seal any more. Having heat from the muffler nearby doesn't help. You will start seeing a leak coming from the fill hole, drops on the ground, and the ***-end of the car will get an oily/dirty film of crap.
Some of us don't have welding machines. I wish some aftermarket supplier would make a replacement cover for the 9-bolt with a normal screw-in plug for drain and another for fill. Just like on the side of the T5. That would eliminate all this hassle of finding a rare gasket and a fragile rubber plug every time we want to change the diff oil.
Any aftermarket house make a replacement rubber plug that fits?
Old Jul 8, 2004 | 05:50 PM
Spdfrk1990's Avatar
Someone is making one go here.Link
Frozer!!!
Jan 19, 2024 04:55 PM
I'llrocya
Feb 2, 2016 11:43 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
86White_T/A305
Aug 17, 2015 12:16 AM
