Carrier Race Diameter
Old Apr 19, 2004 | 07:35 AM
ede's Avatar
ede
anyone have a race they can measure the OD of for me? 7.5 ten bolt. thanks
Old Apr 20, 2004 | 04:33 AM
ede's Avatar
ede
no one has a race laying around the garage?
Old Apr 20, 2004 | 12:23 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I have one I can measure but I wont be able to do so till friday night when I get to my shop to finish the moser rear for my car.I have a 10 bolt in pieces waiting to be assembled for my brother in laws IROC that I will measure the race from when I get there.I will post back with the results.
Old Apr 20, 2004 | 12:52 PM
ede's Avatar
ede
well so far out of posting on 3 boards this is about as close as i've got. friday is fine. thanks
Old Apr 20, 2004 | 03:19 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
According to the GM EPC it measures 2-57/64" & is 27/32" thick. It's a Timken LM501349 cup, if you have a catalog it should give the dimensions.
Old Apr 20, 2004 | 06:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Carrier Race Diameter
The carrier race OD from an original '92 factory rear is 2.890" +- .002", the tolerance is because I used dial calipers. This matches w/Rick's dimension. The race is marked "TIMKEN LM501314 USA YL."
Didn't see your post 'til today, else had it for you last night. . .
RBob.
Old Apr 20, 2004 | 07:26 PM
92Z-666's Avatar
Car: 92Z
Engine: 6.6
Transmission: 6
http://www.timken.com/india/tilbrguid.pdf
The series 3 factory carrier bearing race is:
LM501314 (as expertly mentioned already)
race OD = 73.431mm = 2.89098 in.
Useful data if yer setting pinion depth, after exploding a set of richmonds Don't forget to verify the carrier centerline! I see no decent 'thirdgen.org' tech articles on gear swaps that goes into the process of setup... someone should take care of that.
Old Apr 21, 2004 | 04:42 AM
ede's Avatar
ede
thanks i've been looking for the diameter for a while now. going to make a pinion setting tool.
Old Apr 21, 2004 | 06:08 AM
Ricktpi's Avatar
You guys are right the LM501349 is the cone & LM501314 is the cup. It's not marked as to which is which in the EPC.
Old Apr 21, 2004 | 06:12 AM
Ricktpi's Avatar
Originally posted by 92Z-666
[BUseful data if yer setting pinion depth, after exploding a set of richmonds Don't forget to verify the carrier centerline! I see no decent 'thirdgen.org' tech articles on gear swaps that goes into the process of setup... someone should take care of that. [/B]
Gotta love the Ford 9". You just have to measure from the side carrier cap parting line to the stub on the pinion to set the pinion depth.
Old Apr 21, 2004 | 06:17 AM
ede's Avatar
ede
only did one 9" and that was a long time ago and i know most of it seems backwards from gm rears. on a gm rear aren't you doing the same thing that you just said about the 9"?
Old Apr 21, 2004 | 08:34 AM
92Z-666's Avatar
Car: 92Z
Engine: 6.6
Transmission: 6
I put a mark-williams 9" conversion in my 11-sec iroc, I found the total package a bit on the heavy side (as far as weight) and common complaints include the one about the efficiency being less than the 12 or 10 bolt. a rebuilt stock trak-lok is still not a real nice posi IMO, and the good stuff (auburn for 9 inch) is $$$!
then again, I was never able to blow it apart like I did the 10-bolt.
Hey, whaddya do when your carrier bearing surfaces are 0.007 different from each other... take an average?? (don't say line-hone.. I don't wanna hear that) :/
Old Apr 21, 2004 | 10:00 AM
ede's Avatar
ede
the way i use to do it untill i get this new tool made is use a piece of aluminum to span the opening and use it as a datum surface so in effect i would be taking an average of the two surfaces.
Old Apr 21, 2004 | 10:29 AM
Ricktpi's Avatar
Just opposite here. Have not done a GM rear in quite a while. It may be the same. Just saw a pinion depth kit in Jegs for $100. Not sure if it would worth it to you or not. I run a straight edge across the parting lines & measure with snap guage or depth micrometer.
As far as being .007 out, I would use the straight edge method & take the measurement at the point where the ring & pinion make contact. Then fine tune it by checking the pattern.
Old Apr 21, 2004 | 10:35 AM
Ricktpi's Avatar
I would agree on the heavy part. I have heard numbers like a 12 bolt uses 2% more power than 10 bolt & a 9" uses 2% more than a 12 bolt. As far as a Trac Lok goes I have no complaints, for $60 you can rebuild them very easily. An Auburn you have to replace the whole unit. $$$
Old Apr 21, 2004 | 10:59 AM
ede's Avatar
ede
someone posted not long ago about the universal pinion setting tool, it's junk and a waste of money.
Old Apr 21, 2004 | 12:21 PM
Ricktpi's Avatar
I figured as much. That's why I didn't get one myself. I was just recently talking to an older guy that does drivelines & custom chassis for a living. He said 9 out of 10 12 bolts will take a .030" shim & you are good to go. From anyone else I would say it's BS, but this guy is very detail oriented. ??
Old Apr 21, 2004 | 12:36 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
That was probably me..I finally got it to work.I am semi pleased with the results..tooth pattern revealed it was close so I guess it paid for itself.Would I recommend it..NO.In case anyone does purchase it..get a good dial indicator..the one provided was a real piece of s**t.Otherwise add a good quality dial indicator to the price...or just save and get the T&D tool.
Old Apr 21, 2004 | 02:08 PM
92Z-666's Avatar
Car: 92Z
Engine: 6.6
Transmission: 6
Not the flat cap surface, although uneven cap surfaces can affect the results of the measurements if you 'switch off' without recalibrating the depth tool... I meant the bearing bowl depth itself. Mine are 0.007 off, one is deeper than the other as measured from ONE cap surface.
If you SPAN the cap surfaces and measure the bearing bowls you're only biasing the reading by the short distance from the cap to the bearing bowl. in my case I might get 0.001 more on one side and -0.001 less on the other.
THats neither here nor there.... theres sooo much wrong with not using one of those cap-seated rear-specific tools if you're an **** retentive machinist. It gets you close enough I guess... the marking compount tells the truth in the end.
Good luck with the new tool... if it is sound machinist engineering I'd pay 75 bucks for it if it included a dial guage that wasn't made in japan.
Old Apr 21, 2004 | 02:13 PM
92Z-666's Avatar
Car: 92Z
Engine: 6.6
Transmission: 6
I'll put my vote in for P.O.S.
I couldn't get it to repeat a calibration, it was off by as much as a boatlength through sucessive calibration passes... 0.003 sometimes. the cal cyllinder surfaces were not flat! they wobbled around and caused the dial to move. It seemed the spot that the tip rested in the cal cyllinder was not flat either.
I up my offer to $100 for a new tool
Old Apr 21, 2004 | 02:19 PM
92Z-666's Avatar
Car: 92Z
Engine: 6.6
Transmission: 6
Mine WAS rebuilt.. that's the last time I let someone else do it for me
If theres a way to get more clamping force outta the 9 inch trak-lok, I can use that info if you have it. I abandoned the whole idea and went back to a 4th-gen 7.625 10-bolt. I'm trying to keep the number of ford parts at zero .. I had to listen to the purists whine...
Old Apr 23, 2004 | 08:39 AM
92Z-666's Avatar
Car: 92Z
Engine: 6.6
Transmission: 6
Oh, if anyone's really po, they can do what I did, but skip all the $$$ dial guage and measurement stuff.
Take your OLD front (large) pinion bearing and have a machine shop hone it out 0.002. Use this 'checking bearing' on the NEW pinion, trial-fit shims (start LOW) and use marking compound. voila, a $10 solution that eliminates multiple press-fits and re-press-fits and eliminates the need for expensive measurement tools and measurement skills. Final step is press-fit the NEW bearing and re-check with marking compound. Note you must be able to diagnose pinion markings to get it right with no dial guage...
an excellent series is here:
http://www.rubiconusa.com/articles/article.asp?artid=97
no, its not mine... but its a nice job!
use as general info, its not specific to my 10-bolt.
Backlask is still a measurement nessecary though.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
