87 T/A rear end. CAN IT HOLD UP TO A BIG BLOCK
Old Apr 20, 2004 | 01:30 PM
81LT4's Avatar
Car: 1991 GTA
Transmission: AUTOMATIC
I have a 87 T/A body and want to make it a straight line
car, with my 454. What kind of HP can it handle.
I would hate to do this, then bust it. Its a stock rear.
Old Apr 20, 2004 | 01:41 PM
OMINOUS_87's Avatar
LOL.
The stock axle behind a big block are merely delusions of grandure.
Old Apr 20, 2004 | 02:34 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The stock rear or trans for that matter won't hold up to the torque of a 454 for very long, especially with sticky tires & hard launches.
Old Apr 20, 2004 | 02:42 PM
81LT4's Avatar
Car: 1991 GTA
Originally posted by OMINOUS_87
LOL.
So i take it no!! do you know the most it will handle.
what would have to change? carrier, axels, both.
Old Apr 20, 2004 | 02:43 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the stock axle cannot withstand a 152rwhp L03 if it has slicks on it... nevermind a big block.. lol.
Old Apr 20, 2004 | 02:44 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
its the design of the small 10bolt..
the only real solution is to swap to a diffrent rear.
you can buy 12 bolts and 9" housings that bolt in as factory replacements.... its a lil pricy, but worth it....
Old Apr 20, 2004 | 02:45 PM
81LT4's Avatar
Car: 1991 GTA
I have a 400 trans. What about just street use, still
hard on the rear, you think.
Old Apr 20, 2004 | 02:53 PM
81LT4's Avatar
Car: 1991 GTA
I know my 91 GTA stock 350 has like 220 hp
and with the TPI it gives lots of torqe right.(more than the hp)
I would even think the rear is the same as my 87,
or no. I rip off the line hard, and never had a problem
with the rear. But then again its not a big block.
Old Apr 20, 2004 | 02:55 PM
81LT4's Avatar
Car: 1991 GTA
And still keep my disk rear brakes?
Old Apr 20, 2004 | 03:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
yes. you can keep your factory discs.
you can also put on the later brakes.. the best being the 98+ "LS1" ones
Old Apr 20, 2004 | 03:06 PM
Ricktpi's Avatar
If you baby it all the time it would last, but something tells me that won't happen.
Old May 4, 2004 | 08:26 AM
5speed4life's Avatar
Car: 83 Trans Am
Engine: 355 4 bolt main, One day it will run.
hmm, if he baby'd it all the time, why would you throw in a big block in the first place?
Im contimplating the same idea, but im gona try a 9"
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
