corvette servo
Old Apr 22, 2004 | 08:33 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
corvette servo
hey, hows it goin. my car (92 rs camaro) has a slight slip in third, and it hasn't gotten any worse or any better for the last year and a half or so. i was told it would possibly be a loose band, or fluid pressure. it didn't start slipping untill about a month after i installed a b&m shift improver kit in my tranny (700r4-4l60). i was told if i installed a corvette servo, it could possibly eliminate this problem. could someone please help me out. thank you, chris
Old Apr 22, 2004 | 08:39 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
from what i have read, the corvette servo was designed specifically to take care of the "flare up" on the 2-3 shift. hopefully this helps and i know there is someone out there that knows a little more, so hopefully they will chime in.
Old Apr 22, 2004 | 08:43 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
what is "flare up"?
Old Apr 22, 2004 | 09:21 PM
White91GTA's Avatar
Engine: 5.7L TPI
on the 700r4 transmissions, it was very common for them to have this flare up on the 2-3 shift. what it is, is simply that at the time that the tranny should shift, the rpms jump up a couple hundred rpms or so before it shifts. so it revs the engine before shifting. this was a common problem that was known to gm about these trannies.
Old Apr 22, 2004 | 10:00 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
ahh so that must be what my problem is, must not be slipping then, so im guessing a vette servo would be a good idea? thanks
Old Apr 23, 2004 | 07:58 AM
White91GTA's Avatar
Engine: 5.7L TPI
does yours do it on the shift or after the gear has engaged? how many miles are on the car?
Old Apr 23, 2004 | 11:44 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
it does it on the shift
like right as it is shifting to third, and it makes a clunk sound. for the longest time ive been saving money for a rebuild. hopefully this is just the flare up you mentioned
Old Apr 23, 2004 | 06:41 PM
White91GTA's Avatar
Engine: 5.7L TPI
That is what it sounds like to me. Mine does it also and I am going to try to save the money for a rebuild or else get another damn loan. I hate borrowing money. Only thing that mine does not do that yours does is make the clunking noise that you mentioned.
Old Apr 24, 2004 | 01:25 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
well im gonna try the corvette servo out, hopefully that will fix it, if not, maybe time for a rebuild
Old Apr 25, 2004 | 12:37 AM
White91GTA's Avatar
Engine: 5.7L TPI
that would be a good idea. if the servo doesn't fix it, then rebuild it and put the corvette servo back in when you rebuild
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
Dragonsys
Sep 25, 2015 03:51 PM
italiano67
Sep 22, 2015 08:42 AM
