TH400 Problems...
Old May 1, 2004 | 06:21 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
TH400 Problems...
I've been having pressure issues with my TH400 since i put it in my T/A a few years ago. I don't drive it much on the street so i haven't addressed the issue yet. When you accelerate normally from a stop light, as soon as it tries to go into 2nd it jerks back and forth really bad untill i wind up the engine a little bit to get it to shift. It's not all the time but just enough to be annoying.
--also--
If i'm cruzing around at about 35Mph and stomp the gas, it should downshift if the pressures are right w/o the kick-down switch being hit (i have a small pushbutton for that purpose on my shifter). it seems like it tries real hard to downshift, but again it jerks back and forth, into and out of 2nd gear and then eventually just stays in 3rd
If I hit the kick-down switch when the car is in 2nd, like going around a turn at about 15 Mph it easially shifts down to first and will boil 'em nicely around the turn.
I'm pretty sure i'm gonna have to rebuild it, but anyone know of anything else that might be wrong. I'm going to change the filter and fluid this week just to make sure but my expierance with auto trannys is limited.
Thanks for any info,
Dave
Old May 2, 2004 | 02:49 PM
louich's Avatar
Car: 75 firebird..9.30@150.5
Engine: twin turbo pump gas sbc
Transmission: glide
Axle/Gears: 3.42s
they can only kick down for certain speeds, so if you modify your governor it might fix the problem
Old May 2, 2004 | 03:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
oooooppppsssssssss
Old May 2, 2004 | 03:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
ooops
Old May 2, 2004 | 03:33 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
ooops
Old May 2, 2004 | 06:30 PM
EvilCartman's Avatar
Car: '82 Z28
Only one problem Trickster, there is no TV cable on a TH400. There's a kickdown switch (which I don't even run) and a vacuum line to the modulator. My only guess is check the vacuum line and don't have anything T'd off from that line cause it can cause problems. It did for me anyway...
Old May 2, 2004 | 06:44 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
OUCH!!!!!!!!!!sorry, missed the TH400. I gotta get a better pair of glasses. Thanks for the info on that EvilCartMan, I appreciate it.
Old May 2, 2004 | 06:48 PM
Engine: 450HP 355
Transmission: TH350
LOL! i was gonna say. i gots no cable.. Thanks for the info tho
I'll try replacing the modulator and the vacuum line, maybe that'll help. Maybe i'll try and record the whineing sound it makes if i pull it back into 2nd or 1st. it's quite loud
Maybe it's time for a new or rebuilt tranny......
Old May 2, 2004 | 07:02 PM
louich's Avatar
Transmission: glide
Axle/Gears: 3.42s
doesn't sound to healthy
Old May 3, 2004 | 05:05 AM
Car: '82 Z28
I've done the same sort of thing hehe
darwinprice
17
Oct 11, 2015 11:51 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
soulblade
Jul 3, 2001 02:26 PM
five7kid
Feb 8, 2001 11:50 AM
