Trouble getting rear out. Please help!
Old May 5, 2004 | 08:37 AM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
Did anyone else have problems getting the bolts out of the trailing arms and panhard bar? Man mine are stuck in there. I tried saoking them in deep creep and everything. I need help gettin this thing out. Also i broke my hard brake line that goes under the car to the front. Where can i get one of these?
Old May 5, 2004 | 08:41 AM
ede's Avatar
ede
tried a BFH? little heat? if you aren't worried about the bushings heat them up and let the cool a bit. should free them up. if you're worried about the bushings soaking them with some r134a would have about the same effect as heat, only in reverse.
Old May 8, 2004 | 03:17 AM
ShadowZ28's Avatar
Car: 91 Camaro RS
Engine: L03 for now......
Transmission: 700R4 for now.......
ya theyre a blast me and a bud just got mine out. we used a lot of pb blaster and wrench extensions.. if you can get them moving at all just spin them with some pb (or your fav penetrating oil) and get it worked in there real good. then the bfh works wonders getting them out
Old May 8, 2004 | 07:10 PM
2out_The_Left's Avatar
you can get another line from www.classictube.com i'm ordering my lines from them, last part of my PBR swap
as for the bolts, i had a hell of a time myself. spin them with the wrench and blast em with a hammer. they will come out eventually. use lots of P oil also, lube is your friend.
Old May 9, 2004 | 05:47 PM
89305RS's Avatar
alright i got the rear out and the new one in. I would reccomend PB blaster to anyone with this broblem and a BFH also works awesome!!
mustangman65_79
Apr 14, 2017 05:37 PM
evilstuie
Apr 14, 2016 08:52 PM
Camarothatcould
Aug 20, 2015 08:49 AM
EFR2000
Aug 18, 2015 08:54 PM
Leggman1
Aug 6, 2015 04:15 AM
