proportioning valve ???
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
In about two or three weeks i am going to swap my 10 bolt open for a 9 bolt posi disc rear.
I was woundering what will happen if i dont change the proportioning valve and just leave the stock drum valve.
Yesturday i went to a place that they only sell f-body parts, and asked for a proportioning valve for the swap i want to do and they told me that i would need to get a 82-84 proportioning valve that came of a car with disc. Becouse the threads on the newer cars were different.
Can anyone give me some advice, or help me with this little problem i have. -Eric
If you don't change the valve, the rear brakes either come in too hard or too soft, I don't recall which but, it don't work proper.
for the aggrivation of having to bleed brakes, might as well do it right the first time, you know what I mean.
Transmission: 4L80E/4L80E
You need to avoid the pre-'84 valves because they have SAE fittings. You need metric fittings.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
wrong.
it works fine.
its not ideal, but it does work good and is far better then stock.
if you do decide to change them, you need a 85-92 4 wheel disc valve.. the earlier ones have a diffrent thread then your 90.
Engine: 5.7 tbi
Transmission: t5
So you are telling me that if i stay with the stock proportioning valve it will work?
Any ways the drums really dont do too much work.
-Eric
-Eric
Car: 91 Camaro Vert
-Eric
-Eric
yes they stop better then the stock drums.
however, they wont stop as fast as they potentially could with a diffrent prop valve. how much of a diff vs the stock Disc/Disc valve? not much. how much vs a aftermarket adjustible... more then enough to justify the cost and time of installation.. in my opinion.
what i would do (or i should say, what i did do) is drive with the stock disc/drum prop valve, and on your next full brake service, put in a new aftermarket wilwood valve. also when you do that, its a good time to put in new flex lines, stainless or factory replacement, doesnt matter.
Car: 1990 Formula
Transmission: WC T5
I got a new prop valve for my 90 formula for my LS1 front/rear disk swap. The GM PART # 10164112 Late 89 to 92 valve 1.5M .
cost me about $65 shipped New.
Originally posted by MrDude_1
wrong.
it works fine.
wrong.
it works fine.
Now hang on, I'm not here to **** and moan but how can you tell me I'm wrong. the only thing you've done is said that yes it comes in a little harder/better. All you have done is eliminate where I was confused.
Don't say I'm blatently wrong when you are clarifing my comment. That's just plain rude and ignorant.
Car: 91 Camaro Vert
If you don't change the valve....... it don't work proper.
they work properly. fine. correctly. safely. however you want to phrase it.
so, i said:
wrong. it works fine.
doesnt seem rude or arrogent to me. it works properly
i apologize if it came off as rude, i was just correcting that last statement.
355tpipickup
Sep 13, 2015 11:35 PM
