Mega Shifter...hard to shift?
Old May 10, 2004 | 12:20 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I'm in the process of installing my Mega Shifter....and geez...from pulling up on the trigger....I'm starting to get a few blisters on my fingers. Is it supposed to be that solid?
Old May 10, 2004 | 01:56 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
yeah they are pretty stiff. Make sure you have the cable looped as the instructions say..and there is some adjustment. But all in all you havce to be pretty rough with them.
Old May 10, 2004 | 02:00 PM
87Formula4bbl's Avatar
Car: '87 Formula
From what I've seen, thats just the way they are. It should break in a bit but probably will still be tough to use. Mine takes some effort to get out of park, you just gotta use some muscle. Keeps the wife from driving it tho (not strong enough, haha).
Old May 10, 2004 | 04:24 PM
Engine: 5.7
Thanks for the heads up guys, I'm using the stock cable and I've adjusted it alot...it goes through all the gears fine....just very very solid...all in all..I'm happy with it!...I haven't completed the wiring or anything yet...just wanted to get the dirty work done first
Old May 10, 2004 | 07:16 PM
HaroGt14's Avatar
Well I used my cable that came with the kit because I heard the stock one was not good to use. and After a day or 2 of going from park to drive it loosened up and its easy to shift now.
Sean
Old May 10, 2004 | 09:43 PM
2out_The_Left's Avatar
i also have a mega shifter. can someone please tell me why my reverse lights stay on in all gears including park??? anyone have any close ups of their wiring to the relay?
Old May 10, 2004 | 09:48 PM
Engine: 406
Here ya go...sorry I dont know if this helps or not.
Attached Thumbnails Mega Shifter...hard to shift?-b-m-shifter-instructions
Old May 10, 2004 | 11:39 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
the way the switches are setup, they can be a bit finicky. i dont have the backup light problem, but i have to occasionally wiggle the shifter from left to right to disengage the safety switch
Old May 11, 2004 | 12:09 AM
Car: '87 Formula
If I remember right, you have to kinda place the switches just right and tighten them down for them to work just right. My backup light doesnt work unless I pull back on the shifter a little bit while its in Reverse.
Old May 11, 2004 | 01:50 AM
Engine: 5.7
well..I just hooked up everything and it's working great. I didn't use the relay or anything and it works fine. My reverse lights work great too....never even have to adjust'em. I was going use the cable they supplied...I've done tons of research and everyone I've been contacting hasn't had one problem with using the stock cable. This ONLY problem I'm haiving now..is that when I put it in the over drive.....the top of it hits the console piece...anyone have this problem? I think I might be able to just shave some of the metal down....
Old May 11, 2004 | 05:01 AM
Engine: 406
Have you tried starting the car yet...mine wouldnt start without the switch wired up..or at least connecting the fat wires to bypass the NS switch,,,,
Old May 11, 2004 | 08:37 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
That is why I bought mine! Well, that and not wanting to overshift. I installed mine and didn't have any problems with the cable, (used the B&M cable) but it is a PITA to get out of park, and unill I read the instructions I was having a hell of a time getting it back into park from nuetral (has to be in drive).
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
