ratio gears
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
ok get yourself a grease pencil and a jack.
jack up the rear of the car and put the transimisson in neutral. take the grease pencil or nail polish which ever you get and make a mark on the drive shaft.
Now while watching the driveshaft slowly spin the tire one complete rotation count the amount of times the driveshaft makes complete revolutions in the 1 revolution of the tire. that will give you a round about number.
if the driveshaft spins 3 and 3/4 times to one tire rotation you have 3.73 gears.
Another way to tell is to write down the axle numbers and check it with the site the axle numbers are on the left axle tube (if im correct) and i do not remember how to decode them. hopefully someone else can fill you in on this
Car: 4
Engine: 6
Transmission: 5
Take off the cover and look. It's the only way to know for sure. All the rest of that is guesswork and unreliable. Especially the "codes".
Have you changed the fluid lately? Then it needs it. While you're catching up on the overdue basic maintenance, make a point of counting the teeth. There is no possibility for error there (well, if you can count, anyway).
Car: 1984 trans am
Engine: 5.0 HO L
Transmission: 5 speed
hot69z thanks so much
rb83l69 well I can't say enough
I just buoght the car and i have checked everything i know how i just dont know how to get my ratio
thanks hot69z
one trans am
thanks hot69z
one trans am
Car: 4
Engine: 6
Transmission: 5
Count the teeth on the ring gear, and divide that by the number of teeth on the pinion.
Most all stock gears have the tooth count stamped on the edge, such as "41:11" which would be 3.73 (41/11 = 3.727272727272....). If you spot that on yours while you're changing the fluid this weekend, it will save you the trouble of even having to count them.
Car: 02 z28, 03 wrangler sport
Engine: ls1, 4.0L
Transmission: t56, 4speed auto
i tried jacking up the car and counting the # of rotations of the drive shaft but its only turning about 1.5 times for every complete rotation of the tire. whats up with that?
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
