Tranny fluid
Old May 11, 2004 | 11:05 AM
Quicksilver's Avatar
Car: 1984 Firebird
Transmission: Borg Warner T-5
Tranny fluid
I purchased a 1983 camaro for the transmission(borg warner T-5). Well in the process of removing it i drained the fluid and it came out a brownish black color and smelt burnt. The tranny worked b-4 removal or at least through first and reverse so i didnt know if i should take it to someone and get it rebuilt or just add new tranny fluid and bolt it back up or put the old back in. Thanks for your help!
Old May 11, 2004 | 11:22 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
well i definately wouldnt put the old back in thats for sure but i would definatley drain it completely and put fresh fluid in and you should be fine i would think
Old May 11, 2004 | 09:25 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
dont forget the new filter also..very easy to change.
Old May 11, 2004 | 10:28 PM
THEGENERAL's Avatar
definatley
Old May 12, 2004 | 12:00 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
T5's have a filter?
(Hey, I don't know - I've never had one.)
Old May 12, 2004 | 07:51 AM
Engine: 406
oops..guess I should have read the post better good ole' 5-7, always has a fellows back.
Old May 12, 2004 | 11:40 AM
THEGENERAL's Avatar
yeah me too....lmao ...oh well we all have brain farts ...LMAO
Old May 12, 2004 | 04:03 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
i don't know about the older t5, but the one in my 92 uses ATF. If you dont mind the poss. of removing the tranny again, try fully synthetic atf, it worked wonders for mine, very improved shifting.
but then again yours might use gear oil. idk
if you want to be safe though, have it rebuilt, there is a range of improvements possible, including using wc or stronger parts
Old May 12, 2004 | 05:50 PM
Engine: 406
yeah I run synthetic in my T-56 also, always have.
Old May 13, 2004 | 02:40 PM
THEGENERAL's Avatar
yeah i would have to agree that running synthetic would definatley be the way to go and maybe add a little life to that transmission also
Old May 14, 2004 | 12:34 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
That older T5 is a non WC tranny. I think they take gear lube, not ATF. The WC T5s definitely take ATF. I have a WC T5 in my 88 IROC and I use M1 synthetic ATF.
Old May 14, 2004 | 11:58 AM
THEGENERAL's Avatar
what years did they change the transmission to the WC ?? just curios ...i dont have any idea ...
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
