Moser 9" and rear U-joint????
Old May 15, 2004 | 04:21 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Anyone have a p/n for a u-joint that lets me use my stock drive shaft w/ my 9"?
Old May 15, 2004 | 11:30 PM
IronbackTA's Avatar
Car: 86 Aero TA
Engine: ZZ4
Transmission: T-56 Rear: Dana 44
If you have a 1350 yoke on the 9 inch, I think a Precision #348 will work. I think NAPA uses the same #. BTW, this is a bastard u-joint and not very strong. Why not upgrade to a 1350 joint driveshaft?
Old May 17, 2004 | 09:54 PM
Lonestar's Avatar
Car: 1985 Firebird
Engine: 327
Transmission: TH350
The "bastard" u-joint is as strong as stock. I have broken everything else EXCEPT the u-joint (including grenading a 9" rear end that went as far as bending the axle housings).
Old May 18, 2004 | 08:22 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
i just broke that very joint. Damn thing pretty much exploded.
Denny's N20 shaft is on the way
Eric
Old May 18, 2004 | 11:48 AM
IronbackTA's Avatar
Car: 86 Aero TA
Engine: ZZ4
Glad you had good luck with it! After the second "bastard" fragged and took out the pinion yoke, I up-graded to 3 1/2" aluminum shaft, billet yoke and 1350 SOLID u-joints. The 1350 up-grade is cheap insurance, especially for people running T5 & T56 trannys.
Old May 18, 2004 | 03:54 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Are you sure the stock driveshaft is long enough? Mine needed to be 2" longer, so I had a driveline shop make me a 3.5" steel one with 1330 joints was about $265 2 years ago.
Old May 18, 2004 | 09:36 PM
Lonestar's Avatar
Car: 1985 Firebird
Engine: 327
Transmission: TH350
The stock driveshaft should be long enough, provided the 9" rear is mounted correctly. I suppose I could be wrong on the 3rd gens as I haven't done one yet, I have only done 1st and 2nd.
Maybe I'm lucky on the bastard u-joints, but I've never broken one. I have grenaded transmissions, ripped the tailshafts off, ripped the trans from the engine, blown rear ends and axles and twisted driveshafts...but I haven't broke a u-joint yet. Knock on wood (or maybe I should pray they break, much cheaper than the other stuff)!
Old May 19, 2004 | 09:27 AM
IronbackTA's Avatar
Car: 86 Aero TA
Engine: ZZ4
So with a 700R4 and 9" rear, the driveshaft needs to be 2" longer.
With my set-up, T56 and Dana 44 the driveshaft needed to be 1.25" inches shorter. Interesting. Probably with the 9" low pinion mount it is shorter in length.
Old May 19, 2004 | 09:36 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
When I had a 700R4 and a ford 9" (MOSER) the stock driveshaft was the perfect size.... 2" longer would have shoved the shaft right though the tailhousing of the tranny when the suspension was compressed...
I did not need a longer one untill I switched to the TH400...
I also would not worry about basturd u-joints.... At least on mine(TPIS Shaft) I used a basturd one...The Bearing Caps were different and there was slightly less matl on the shaft side But hardly a cause for concern.... Under a supercharged car at the time I completely thatshed the TH400 But the u-joint still lives on in someone elses car...
Old May 25, 2004 | 06:44 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Ok, still have a problem. It looks like I don't have a 1350 yoke. I bought a u joint for that yoke and it was too big. Any suggestions? How do I measure one of these so I can give the dimensions to the people over the phone? This is the only thing that's keeping my car from moving, and it's getting a little frustrating.
Old May 25, 2004 | 07:43 AM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
ford used 2 different ends.. both used 1330 series bearing caps...but one was wider than the other...wider one is preferred and more comon....
BUT anyway here is a webpage that helped me get the right joints for my original setup....I used the specs on the page to measure the shaft and yoke and then called them...
http://www.rockforddriveline.com/universaljoints.htm
You may have to look around the site to find all of the specs but its all there...if not call them..This page link is to pick the style ends you need...they have seperate pages for conversion joints etc etc...But this gets you started on dimensions...
Old Oct 9, 2011 | 03:59 AM
Fermin91rs305's Avatar
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Re: Moser 9" and rear U-joint????
sorry to jump in on this post but seems like you guys were talking about what i need help in. I have a built 700r4 just installed and also a moser 9'' rear with detriot locker 4.11 gears. My question is i have the stock driveshaft but my car shakes alot like after 45-55 and off gas it shakes bad. I was wondering if the length of the shaft is to long or short.
Old Oct 24, 2011 | 11:28 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
The correct 1350 conversion u joint is Precision 447. I JUST installed one.
http://www.summitracing.com/parts/PCN-447/
I have the same basic rear you have except mine is a currie housing, Strange center and 4.57 gears. I LITERALLY finished it last night and am noticing a vibration around 55mph like you. I'm ordering a shaft from Strange and hoping it'll fix it.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
