T5 Buildup
Old May 17, 2004 | 10:39 AM
IANTI's Avatar
Car: 88' IROC
Transmission: 5 speed
T5 Buildup
I am going to be obtaining a rebuilt 350 low miles and recently rebuilt the owner says it has about 400 horsepower but i'm hoping it has at least 300. The problem is I want to rebuild the stock t5 so that it can withstand the hp/torque of the 350. Is this possible if i brought it to a rebuild shop?
Old May 17, 2004 | 12:23 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
It isn't horsepower that breaks transmissions; it's torque. Is the new motor going to be fuel injected (TPI/TBI) or carb?
What kind of rear end are you running? What kind of tires? How will the car be used (drag, street, street/strip. ect.)?
Old May 17, 2004 | 01:50 PM
IANTI's Avatar
Car: 88' IROC
it's going to be a carbed car, stock rearend for a while but a rebuild is in the future and it's going to be used for the street!
Old May 17, 2004 | 04:05 PM
The T5 should fare fairly well in a street car. Most likely you will smoke the tires before you put enough stress on the trans to break it.
I would recommend a complete rebuild with upgraded 2nd and 3rd gears (double moly). Buy a good shifter (I recommend Pro 5.0, but Hurst and others have good reps too). I wouldn't powershift it too often either. A steel bearing retainer is also a good way to go.
A reputable local shop should be able to handle the work for you. If you can't find one you like drop me a PM and I'll rebuild it for you.
Old May 17, 2004 | 08:00 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
TKO--how much $$ would this rebuild of a T5 to handle 400hp/torque for the street run?
Old May 18, 2004 | 05:40 AM
I believe that the complete rebuild kit (synchros, bearings/races, seals) runs about $185. The steel bearing retainer is around $60. The double moly 2nd & 3rd gears are about $65 each. The labor should run you roughly $200 with the trans out of the car.
Grand total: $575.
Old May 18, 2004 | 07:40 AM
IANTI's Avatar
Car: 88' IROC
this sounds good hopefully it will last me through summer because next winter i will prolly go for a tko or a t56.
Old May 22, 2004 | 11:15 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
TKO--OK, how about shipping to your shop for this rebuild? Do you have a favorite shipper?
Old May 23, 2004 | 06:07 AM
pecha's Avatar
Car: 98 T/A
Engine: ls1
how about this
Old May 23, 2004 | 10:34 AM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Pecha--outstanding! How are your roads in Poland? What rear end gears do you run?
Old May 23, 2004 | 05:54 PM
berlinettakid's Avatar
Car: 86 T/A, 86 z28, 79 berlinetta, 69 chevelle (totally rusted)
Engine: 350's in the f-bodys. 327 in the works for the T/A, MIGHT go with a 383, none in the chevelle
Transmission: T/A has a 5-speed, z28 has a 700-r4, th-350 in the 79' (5 or 6-speed soon), and none in the chevelle
http://www.gforcetransmissions.com/
That's who I'm going to use.
Old May 23, 2004 | 08:09 PM
eddie jr's Avatar
Just curious, is a steel bearing retainer better to prevent wear on only the outside (TOB) or the inside as well (input bearing)???
Old May 23, 2004 | 08:57 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The stock one on f-bodies is steel already, so this is unnecessary.
Aluminum ones wear out and screw up. That's why Mustangs get them as an upgrade that should have been there from the factory.
Old May 25, 2004 | 02:41 PM
rbjones, I prefer to use UPS. They should ship a trans for about $65.
jmd, thanks for the heads up on the bearing retainer. I wonder why the Mustang got the aluminum one? Typical Ford I guess. They do things 95% right, but the 5% they do wrong will drive you nuts!
Old May 25, 2004 | 02:51 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Hanlon Motorsports just quoted me $250 labor to rebuild my T-5 trans, plus parts and shipping. They said $170 for the complete rebuild kit or $89 for just the refresh kit.
The upgraded 2nd and 3rd gears sounds like a great idea...along with making sure you have the steel retainer...
www.hanlonmotorsports.com
Old May 25, 2004 | 03:30 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Ditto!
Old May 25, 2004 | 09:42 PM
Engine: LS3
Transmission: 6L80E
The only downside to G Force is the $$$...for that kind of money, I would rather buy a Tremec or do a T-56 swap.
Old May 26, 2004 | 09:23 AM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
TKO--Well, I'm gonna do this TKO upgrade--established firm, right in the ballpark on price, knowledge on those internal parts. GForce makes an excellent tranny--straight cut gears look like an old M22 inside--but, good grief, the $$$! Other companies provide great service on total packages but again, the $$$! I'm not rich, not in that market.
My Camaro is a long-term project--already built the rear end with 28 spline Torkelson, Mosers, 3.73's and boxed arms--this TKO upgrade to the WCT5 will make the drive train ready for 400 hp/ft lbs. The only racing it will see is SOLO II and open road, amateur stuff, and what I don't spend on the drive train I can put in the motor, suspension and motel rooms.
Old May 29, 2004 | 09:05 PM
60504's Avatar
Car: 92 Camaro
Engine: ZZ4 350 HSR
Transmission: G-Force T5
For $1300 delivered, I got the G-Force T5 prepped by "Bubba" with a "600hp" rating...No other parts to buy or mods required, unlike the T-56 or Tremec...Sounds like a sweet deal to me
Old May 29, 2004 | 09:10 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Yeah--that sounds like a pretty good price on a turn-key 600hp tranny.
unknown_host
Aftermarket Product Review
59
Sep 3, 2001 10:59 PM
sharky55
Aug 2, 2001 04:17 PM
scottmoyer
Jun 12, 2001 02:45 PM
