new axel seals leaking?
Old May 24, 2004 | 07:09 PM
86_Dan_Z28's Avatar
Car: 86 Z28
I recently got a rear end put in with brand new axel seals. Now I am getting oil seepage, I know that it is gear oil because of the smell. What could cause them to go bad?
Old May 24, 2004 | 07:40 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
If there isn't a groove cut into the axle shaft from the old seals, chances are either the seals were junk, or maybe installed dry and burned up. I always put a little grease or gear lube on the lip of the seals. I burned up 2 sets on my Jeep before I figured out that I need to put lube on them.
Old May 24, 2004 | 09:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What do the axle bearings look like?
They're the usual cause of leaking seals.
Old May 25, 2004 | 04:57 AM
ede's Avatar
ede
i'd go with RB and say bad bearings. my second guess would be you installed the seals dry and they got fried.
Bubbajones_ya
Jul 6, 2024 08:32 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
bubbaz28
Sep 18, 2015 02:09 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
