did 4.10 is overkill??
Old Jun 4, 2004 | 10:21 AM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
I got a 88 camaro with a 355ci vortec with a 100hp nitrous shot.My best track time is 12.40@110.6mph with a stock torque converter on a th700 and a 3.42 gear with 27.3 MT et drag slick.
I am cant make my choise betwen the 3.73 or th 4.10.the mpg is not a concern.I just dont whant to overkill...what should i get??
27.3"tires@6000rpm
KM/H MPH
3.42:1 1-73.6 46
2-139.92 87
3-228 142.5
4-325 203
3.73 1-68.33 42
2-128.28 80
3-209.10 130
4-298.73 186
4.10 1-62.16 38
2-116.70 72
3-190.24 118
4-271.77 169
Old Jun 4, 2004 | 10:32 AM
25THRSS's Avatar
What rpm does your engine make peak power at?
Old Jun 4, 2004 | 10:35 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Frankly, if I was you, I'd leave the gears alone, and get a converter first. Just in terms of bang for the buck.
3.73 is usually about all you want to go to with the 700, because 1st is so deep. IMO there's not enough difference between 3.42 and 3.73 to make it worth doing, until you deal with the converter.
Dyno your car and see where it makes power; get a converter that stalls 400-500 RPM below its peak torque RPM; and shift at a RPM such that after the shift, your RPM is at the peak torque again.
Always pick the low-hanging fruit first.
Old Jun 4, 2004 | 12:50 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
And, are you crossing the traps at a high enough rpm?
Shifting at 6200 but crossing the line at 5200 in 3rd? Might want to add some gear in that case, but the tq. converter would be a wise move to improve your e.t.
Old Jun 4, 2004 | 01:05 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
torque converter
Peak power should be at 5600.So do you think that a 2800 stall with a 3.73 should be the best setup for my camaro .Did they sell stall torq with the 27 spline lockup and a 2500 to 2800 stall speed? B&M or TCI
Danger Mouse t15
superchevy
rpm tq hp
2600 379 188
2800 384 204
3000 404 231
3200 427 260
3400 433 280
3600 435 298
3800 437 316
4000 432 329
4200 433 347
4400 434 364
4600 439 385
4800 433 396
5000 423 402
5200 411 407
5400 401 413
5600 389 415
5800 365 403
I got the same setup except for the cam they got the xe262h and i got th xe268h
http://www.superchevy-web.com/tech/0...m15/index.html
Old Jun 4, 2004 | 01:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
At least 2800, maybe more like 3200.
You'd do better with Performance Industries. Their "Vigilante" product. In Oakland TN; another almost-suburb of Memphis, kind of like TCI being in Ashland MS.
Old Jun 4, 2004 | 01:13 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
finish line
I finish the 1320 in 3 gear at 4600rpm (111Mph)
Old Jun 4, 2004 | 01:15 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Thanks RB83L69
:hail:
Old Jun 4, 2004 | 02:50 PM
nolanr0413's Avatar
Car: Trans am
well, i have 4.10 gears and stock height tires, 25.6 or something, i was trapping in third gear at 5500-5600 rpms. I think your gonna want 4.10 gears, i mean you still have od and you tall tires, you will be fine.
Old Jun 4, 2004 | 03:05 PM
25THRSS's Avatar
You sure you're crossing the traps at 4600? That would mean you have almost no converter slippage at all.
Old Jun 4, 2004 | 04:49 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Yea, that`s kinda low even for a 342 cog...I have 4.10`s with the 26 inch drag radials, big block 477, 3,000 nine inch non lock up stall and It goes thru the traps right at 7,100 rpm@ 118.xx(in third gear a-4)
I`d do the 3.73`s if I did it again
Old Jun 7, 2004 | 09:48 AM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
It could be more 4700rpm
Old Jun 10, 2004 | 12:36 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Do you have a factory tach? If yes, that might explain your oddly low trap rpms.
Old Jun 11, 2004 | 01:33 AM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
My tach is a sport comp 5"monster...it should be acurate.
Old Jun 11, 2004 | 01:36 AM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
here
Old Jun 11, 2004 | 05:58 AM
Adrenaline's Avatar
Car: 92 Camaro RS
Do you plan on leaving this motor alone for a while?
if you do then i say go with the 4.10's
but if you plan on putting more power and goodies on the car, your gunna need more top speed, pointing to the 3.73.
Old Jun 13, 2004 | 10:36 AM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
i am planing a 3000rpm stall and the gear. :lala:
Old Jun 16, 2004 | 09:24 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
if you're going for performance, the 4.10 is the way to go. without alot of explaination, that is roughly the naturally asperated gear ratio of choice.
Old Jun 17, 2004 | 02:59 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Choise is done
After hours of calculs and reflexion i made my choise on the 4.10 because i am most of the time on motor so my trap speed is 104 mph my tires are 28x9x15 (27.3") and the gear is 4.10 = 5250 rpm .With 5% of torque converter slipage=5512rpm wich is ok.For the nitrous...trap speed is 110mph with 4.10 =5600rpm and with 5% of torque converter slipage=5880rpm thats is also ok . So i should be ok to 113 with 5% slipage at the 6000 cutoff. At the very least if i get more than 113mph i will pull my cutoff to 6200rpm . Thanks to everyone that help me make my choise!! i will bring back the results as soon i get back to the track..
F-body-fan
May 4, 2026 09:42 AM
6speedIROC
16
Mar 15, 2023 08:33 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
S10K20
Oct 7, 2015 06:45 PM
fasteddi
Sep 10, 2015 09:32 AM
