Which T-56 Works?
Old Jun 7, 2004 | 01:30 AM
Adrenaline's Avatar
Car: 92 Camaro RS
Which T-56 Works?
Ive been considering the t-56 swap for my automatic. ive read a few places that the LS1 6 spds, only work on the LS1's? so how do i know which T56 to get? id be pissed to buy one and have it not work. Anyone know how much a shop will charge to do the swap? and does anyone have a t 56 for sale? :-D
thanks
Old Jun 7, 2004 | 06:23 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The LS1 version does not work directly on a Gen 1 SBC.
93-97 Camaro or Firebird with LT1 is the one you want. Get the trans, flywheel, bell housing, clutch, hydraulics, shifter. You'll need some method of re-calibrating your speedo as the LT1 VSS gives about 20 pulses per revolution instead of the 4 your speedo needs. Your drive shaft and pedals will work. You'll need to fab or otherwise acquire a crossmember.
Old Jun 10, 2004 | 08:55 PM
Adrenaline's Avatar
Car: 92 Camaro RS
So the ls1 6 spd only works for the ls1, will the lt1 6 speed bolt to any chevy small block? the 305, or maybe a 355 i built myself?
and the one i built is carburated, are there any problems i run into by that?
Old Jun 10, 2004 | 09:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The one I have bolted up to my 83 L69 at the moment seems to fit like a glove. So yours probably would too. The flywheel could be an issue though; if your motor is a 2-piece rear main seal one (pre-87) then you'll need a special flywheel.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
cRoe4
Aug 7, 2015 08:46 PM
