700r4 to 4l60e swap?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Take the yellow and purple wire from the VSS and run them to pin D4 & E4 of connector C100 and then to the buffer box. There is only one wire going from the buffer box to the ECM and that is at pin "A10" like this picture.
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You may be able to get a 4'th gen PCM and use LT1 edit and program it just to control the trans. The stand alone 4l60e controlers are really expensive.
Re: 700r4 to 4l60e swap?
I was wondering where can I find the VSS buffer box
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
Does this help...
https://www.thirdgen.org/forums/tran...gital-sgi.html
Also...with the right truck PCM, it's possible to convert the PCM to batch fire a TPI and control a 4l60E w/ added wiring of course.
Car: 1984 Trans AM
Transmission: 700-4r
Why change from the 700-4R. Good tranny & no messing with electronics and very strong.
I believe that there a few companies that make a controller/computer for the 4L60E or 4L80E.
