TV cable adjustment...now bad
Old Jun 25, 2004 | 07:13 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
ok so i was reading a post about the TV cable and if the shifts r "loose" to adjust the cable. so i looked in my haynes manual and it sed the same thing. so i did it, i did word for word what the book says (depress and hold metal tap and move the cable housing into slider until it stop against collar. release tab) then it says, for my carb model, to open the throttle all the way and the cable will ratchet through the slider...well i did that but didn't notice any noise from it ratcheting. ok so that all sed...
i took it for a ride up the road and while lightly accelerating it jerks forward from 1st to 2nd and doesn't shift until 3k, and it doesn't seem like it hits OD while going up even the smallest of hills. like it just doesn't seem right . also when i'm on level ground cruising, it's at 1k rpm and when i hit the gas it goes to 2 k then jerks to accelerate. did i really mess something up here to did i do the adjustment wrong??? i was also thinking that MAYBE the tranny had to relearn, but i'm don't think we have cars like that, or do we?
please HELP, BTW 84 TA L69 700-R4
Old Jun 26, 2004 | 09:58 AM
chio987's Avatar
Engine: 305 4bbl HO
no body
Old Jun 26, 2004 | 07:05 PM
copperhead110's Avatar
It sounds like you did the adjustment correctly.
Did the cable extend out some after you adjusted it and just didn't click? Does the cable stay where the adjustment left it?
I did this adjustment because my car was shifting into 2nd at WOT at 3k. After the adjustment, it now shifts at 4.5k like I expect. I only got one click when I adjusted it. Everyone else seems to get a lot of clicks.
Did you try a search to read what happened to other people? Remember to try searching for tranny and transmission. I had trouble because I was looking for transmission posts.
I don't believe the tranny needs to relearn anything.
Old Jun 26, 2004 | 10:01 PM
chio987's Avatar
Engine: 305 4bbl HO
ya i really couldn't find anything about it, and i'll be looking into it tomorrow alot more. like if i'm able to get ahold of a camera with video, i can drive it and u can see what i mean. like at WOT it seems to be fine.
Old Jun 28, 2004 | 12:55 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
yeah im having the same problem chio right now. I did everything you did and now the tranny jerks going into 2nd gear until it warms up it wont do it again. im going to do it all over again. when i first did it, i only got 1 click. let me know what happens with you dog.
MM2Robinson
Oct 1, 2017 09:16 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
