Take apart t-5 yoke?
Car: 89 Formula
Engine: 355
Didn't find the answer using the search so is there a take apart yoke that is made for or is usable for the T5?
Car: 4
Engine: 6
Transmission: 5
I've never seen any such thing for any transmission.
However, the T-5 uses the same yoke as a 350 or PG (later model) or 700 or the smaller 4-speeds; so anything that fits those should work. Not the same as early PG or 400 or the larger 4-speeds.
Car: 89 Formula
Engine: 355
Car: 4
Engine: 6
Transmission: 5
Well I'm an idiot, so in cases like that I just go straight to the mfr's web site. You'll have to excuse me.
http://www.moserengineering.com/mose...s.asp?CatID=11
Which one is it?
The one that fits the T-5 is the TY-600.
I don't see any at all on there for any transmissions, that come apart.
Which one is it?
Car: 89 Formula
Engine: 355
TY650 listed in the summit catalog but like you I went right to the Mosor website and cannot find that one. I bet it would work but at $155 I was hoping there was alt choice.
Check out the desc:
http://store.summitracing.com/partde...N=120%20305102
Check out the desc:
Car: 4
Engine: 6
Transmission: 5
If it fits a Glide, it will fit a T-5.
It uses the wrong U-joint for a stock drive shaft though.... it's set up for the Spicer (outside clip) ones. You'd have to have one of the "conversion" type ones; or put a different yoke on the shaft.
What makes you want to be able to separate the yoke from the shaft?
Car: 89 Formula
Engine: 355
I am putting one in my vette and you have to drop the shaft from the trans end in order to get it out. I can use the stock yoke but then I would have to press the u-joint in with the shaft in the car and would have to remove the trans to get the shaft out.
Car: `86 SS / `87 SS
luvofjah
Sep 26, 2015 08:28 PM
