New Tranny won't go into gear?
Car: '91 Firebird
I got finished putting my T5 in. It won't go into any gear at all, it just grinds. The clutch has been bleed, and fork travels about 5/8 or 3/4 inches. The pedal feels very mushy until it's more than halfway to the floor, then it gets some pressure.
What did I do wrong?
Car: 4
Engine: 6
Transmission: 5
Gotta be the single most often asked T-5 question....
https://www.thirdgen.org/techbb2/sho...hreadid=249172 the first reply, with the pic
Look at the pic, and tell us which way you put the throwout onto the fork.
Car: 4
Engine: 6
Transmission: 5
Look at the little purple circles.
See the little tab looking things in there? they're not supposed to be outside the groove in the bearing; they're supposed to be inside it.
If I was going to write a description to go into a textbook or something of what putting it together with that spring clipped onto the outside of the throwout bearing makes a clutch act like, I could use your exact words. You described it about as accurately and concisely as it can be done.
Car: 4
Engine: 6
Transmission: 5
"The simplest explanation that fits all the facts is usually the right one."
— Occam, ancient Greek philosopher, from the days when all clutches used linkage
Zachattack0925
Aug 12, 2015 09:52 PM
