1990 GMC 1st and Reverse only
Old Jul 21, 2004 | 12:03 PM
bigdadbear's Avatar
Car: Jaguar and GMC van
Engine: 350 /5.7 L
Transmission: 1990 THM700R4
While at a red light - Iheard a slight metallic sound -TING!
When the light turned Green -- Iapplied the throttle and the vehile would not move - With the SElector in Overdrive , Drive OR D2-. When I placed the Selector IN LOW -- THE Vehicle acelerated Very Well-- I Was able to Drive Home - The Vehicle has good Power adn PULL in LOW and REverse ONLY .
I cheecked the Thottle Valve Cable lingage And IT will Operate and Extend approximatelly 1 Inch. .... Do I need to Pul the TV cable at the transmission end for cable issues?
All help would be appreciated ----Should I pull The Govenor --
Please Help - with your suggestions!!! Thanks
Old Jul 21, 2004 | 06:14 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Those are two possible causes for your problem. I would look into the manuel valve in the trans.
Old Jul 21, 2004 | 07:09 PM
bigdadbear's Avatar
Engine: 350 /5.7 L
Thank you for the reply and suggestion
I will not have time to pull the governor or drop the pan to check the Valve til this weekend. If their are any other suggestions or ideas please let me know
Old Jul 21, 2004 | 07:13 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
pull the tv cable off the throttle linkage and pull out on it to see if its still got tension against it
Old Jul 21, 2004 | 07:50 PM
bigdadbear's Avatar
Engine: 350 /5.7 L
I was able to pull it out another HALF - Inch with some force.
It retracted.
Old Jul 21, 2004 | 07:56 PM
THEGENERAL's Avatar
well its not broken or came disconected then .....sounds like you need to drop the pan and check out the insides more
sorry i couldnt help
Old Jul 21, 2004 | 08:17 PM
bigdadbear's Avatar
Engine: 350 /5.7 L
Thanks for the suggestion -- I rather follow up on all the little things first.
would the Transmission be able to go in Reverse and Pull with the shift selector in D1 (LOW) if the Govenor were bad or stripped
Old Jul 22, 2004 | 07:27 PM
dankhound's Avatar
Car: 91 RS
If the govener were bad it should move in all gears. It just wouldnt shift. Another thing that makes me thinks its somewhere other than the govener is that you said it made a noise when you were stopped. The govener is only moving when the car is in motion.
Old Jul 22, 2004 | 07:46 PM
bigdadbear's Avatar
Engine: 350 /5.7 L
Thank you for the response -- I will get into Saturday
I will let you know what everything looks like
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 2, 2015 09:12 AM
raymondandretti
Sep 27, 2015 06:43 PM
