700r4 4th gear: .7:1 before or after lockup?
Old Jul 25, 2004 | 05:09 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
so...is it before or after i lock up the converter? does the gear ratio change or what? i put the tci kit into my car so that i throw a switch and lock the converter up. what does the ratio change to? just trying to get the mph figured out cause i know my speedo is off. i would like to know how fast i am going in fourth with the lock up on and 3.73's @2200rpms with a 235/60/15 tire. at 2200rpms with a .7:1 ratio its 65mph
but is .7:1 before or after lock up?
Old Jul 25, 2004 | 05:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's 0.70 whether it's locked up or not. While it's unlocked you'll have some slippage though.
Old Jul 26, 2004 | 03:03 PM
mw66nova's Avatar
Engine: 7.0L
well, when i throw that switch at cruising speeds i get a 200rpm drop...why is that?
just realized i know little to nothing about automatic trannies.
Old Jul 26, 2004 | 03:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Before the TCC locks up, the engine is turning 200 rpm faster than the input shaft of the transmission due to the slippage in the converter.
Old Jul 26, 2004 | 03:56 PM
mw66nova's Avatar
Engine: 7.0L
ok...and this helps fuel mileage by lowering the rpms of the engine. and before tcc, my rpms on the engine is 2200 and the input shaft is 2000, but the after tcc, they are both at 2000...is my theory right? so should i base my mph after lockup?
Old Jul 26, 2004 | 04:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Ever seen what happens when you take 2 fans and point them at each other, and turn one on? You know how the second one turns, but not as fast as the first? Well that's how your torque converter works; except it has a clutch that can connect the 2 fans directly together - as if you stuck a stick between the 2 blades.
The gears behind the converter are what they are. They have nothing to do with the lockup clutch. When you engage the clutch, you merely eliminate the "slippage" - like the 2 fans - within the converter. That's why the RPM drops, even though the gearing does not change.
Old Jul 26, 2004 | 04:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Right
Old Jul 26, 2004 | 05:26 PM
mw66nova's Avatar
Engine: 7.0L
thanks guys, that's great.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
indygene
Sep 26, 2015 11:21 AM
Dragonsys
Sep 25, 2015 03:51 PM
6998poncho
Sep 25, 2015 02:56 PM
