TV Cable Problems
Old Jul 31, 2004 | 12:50 AM
thunder57's Avatar
Car: 1987 IROC
Axle/Gears: 3:42, 10 Bolt LT1
TV Cable Problems
I did an engine/transmission swap, in the original car the transmission would shift right, and all was good. I believe I pulled on the cable during the swap. I look at the cable and I see a bend in it. I try to set it, I do what I read and I don't hear any clicking. Also it holds the gears for a long time. Any ideas? Could you/how much would it cost to replace this? Thanks for any help.
Old Jul 31, 2004 | 10:23 PM
thunder57's Avatar
Car: 1987 IROC
any ideas? anyone....
Old Jul 31, 2004 | 11:12 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
call up your local parts store and ask how much a tv cable is for what ever the car was you got the engine out of and they will give you a price they arent that expensive .......but before you buy one you should unhook the cable from the carb/tbi/?? and pull on it alittle and make sure it has tension against it when you pull on it because you may have broke it or popped off the hanger in the transmission ............
Old Aug 1, 2004 | 09:57 PM
thunder57's Avatar
Car: 1987 IROC
I'll try that, how would I know if something was damaged inside the transmission? Any idea why I don't hear this "clicking" sound?
Old Aug 2, 2004 | 11:19 AM
THEGENERAL's Avatar
cable is worn , old, the one in my 88 gmc doesnt click either ...i need to replace it because it wont hold a setting for more than two or three days now ...lol.......waiting till payday then im getting a new one for my truck
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
