five speed from v6 same as from v8?
Old Aug 6, 2004 | 09:36 PM
craashmann's Avatar
Car: 1991 Camaro Z28
I found a firebird around town for 500 bucks with a v6 and a five speed. I did a search and cant find if the five speed is the T5? Is it the same as the ones they put in the v8's? Can't find the info anywhere. I want to put this into my 1991 TPI 5.0 Camaro. Thx in advance.
Old Aug 6, 2004 | 10:30 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
i believe they are different the v6 has a totally different bolt pattern than the v8 and i thought i read somewhere that the input shaft on the v6 5speeds are a little smaller if i remember correctly but i could be wrong on that dont quote me .....
Old Aug 7, 2004 | 12:36 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
It is the same for the most part externally, the first gear is different, 4.05 as opposed to 2.95 so you'll take off a little bit faster and run out of first gear quicker, along with a lower torque rating, the input shaft is different so it requires using a slightly undersized early v6 clutch disc or a custom disc, you also need a V8 bellhousing flywheel pressure plate and pilot bushing
$750 L98
Feb 1, 2025 02:25 PM
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
RedLeader289
Sep 23, 2015 06:50 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
