driveshaft noise after 9" install..
Old Aug 7, 2004 | 12:19 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Appears straight. Based on the sound, I guess its not.
driveshaftnoise.MOV
Old Aug 7, 2004 | 04:49 PM
EvilCartman's Avatar
Car: '82 Z28
Holy crap are the u-joints bone dry?
Old Aug 7, 2004 | 08:39 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Rear U joint probably not more than 500 miles since new LS1 drive shaft put in.
Front probably not more than 200 since the tremec was installed. And both still had good grease then.
It was perfectly silent with the 7.5"
Old Aug 8, 2004 | 02:56 AM
Car: '82 Z28
Unbolt the driveshaft and turn the wheels to see if it's still making the noise. Maybe turn the driveshaft while it's still stuck in the tranny but not attached to the rear to see if it's coming from up that end. Anything rubbing anywhere? Never heard anything like that before.
Old Aug 8, 2004 | 08:59 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Do you have drum brakes out back? It might be dragging a bit and may need a little adjustment. Pull off the drums and turn it without the drums. My Tahoe's rear drums sounded something like that when I had them adjusted too close.
Old Aug 8, 2004 | 10:46 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Looks like the Ujoint is too wide for the yoke
This pic of the right Ujoint saddle shows the tang getting crunched down where the middle of the Ujoint is too wide.
The ujoint measures 3.691" and I was told it was a
Rear disk from a 4thgen.
edit
I just touched it with a diegrinder and managed to get it to set down there pretty good. So far no noise after putting the DS back in but that just rolling the wheel. I will probably go for a drive later as the acid test. If it is still noisy I will probably take the yoke and the ds to a local shop
PS, thanks
Keep an eye out for some tire smoke vids soon.. (and this will have an engine audio track, not some lame new age music).
baaawwwaaa..
Old Aug 8, 2004 | 04:23 PM
Car: '82 Z28
So you didn't get the combo u-joint? I had to get one that was a combo 1310 series for the Ford side then 3R for the stock driveshaft. Yours is probably different on the driveshaft side though.
Old Aug 8, 2004 | 11:56 PM
onebinky's Avatar
Maybe get the car up in the air, stick it in drive, and then get under the car and see if you can isolate the noise. Definately wierd though, never heard a noise like that. When the U-Joints in my truck went out, they made a squeeling noise like bad brakes do. The rollers in those were ground to a fine rusty powder though...
Old Aug 9, 2004 | 06:17 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
The front U joint had to be a combo (for the tremec C4 output shaft to the ls1 ds). But I figured the back would be a 1330 ujoint.
My logic was "why would someone go to the trouble to build a 9" with 2" wheel studs and then put the smallest u joint on it.?"
But, so much for that. Someone on chevytalk.com said it was probably a 1310 ujoint.
db057
Jan 10, 2020 08:55 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
loud91rs
Oct 5, 2015 10:05 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
