how do u check tranny fluid on manual trans??
Old Aug 14, 2004 | 01:02 PM
tuffshizit24's Avatar
Car: 1988 pontiac firebird
Engine: formual 305
Hey guys..... I know theirs a plug on the side of the transmission case but i dont see how u actually check the fluid?? answers much appreciated!!!!!!!!!!!!!!!!!
Old Aug 14, 2004 | 01:05 PM
ede's Avatar
ede
add oil untill it runs out, or it should run out when you pull the plug
Old Aug 15, 2004 | 12:36 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
And make sure you check it on the passenger side, not the drivers' side; the plugs on the driver side aren't for filling or checking.
Old Aug 15, 2004 | 04:25 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Make sure the trans is cold too. Otherwise your gonna get a trans fluid bath.
Old Aug 15, 2004 | 09:46 PM
1980z's Avatar
Car: 1994 camaro z/28-1994 z/28 drag car
Engine: 406/ 355
Transmission: powerglide/4l60e
Axle/Gears: 9" 4.56- 3.42
right hand side of tranny, top plug remove and insert your first joint of your finger. if you have oil on the tip of finger it is okay. and do not remove the plug on the left side at the top or you will have to remove tranny and have it fixed.
Old Aug 17, 2004 | 06:27 PM
Engine: formual 305
Thanks guys, now i know where to check it but how do i remove the plug??
Old Aug 17, 2004 | 08:32 PM
1980z's Avatar
Engine: 406/ 355
you should be able to get a 9/16 open end wrench on it or a cresent wrench. if it has a square head plug. or if someone has put a allen head in it it might be a 3/8 allen wrench.
Old Aug 18, 2004 | 02:47 PM
Engine: formual 305
thanx guys
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
maroe624
Apr 16, 2017 08:29 AM
backtothe80s
Sep 5, 2015 12:39 AM
Leggman1
Aug 6, 2015 04:15 AM
