Cleaning 700-R4 'case'
Old Aug 15, 2004 | 12:27 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Ive started tearing down my trans and there are alot of deposits on teh inside of my 700-R4. Pretty much every surface has at least some deposits on it. Should I worry about cleaning the case itself after its entirely disassembled? Would be nice to start off with a clean case to reassemble but it seems like doing any sort of cleaning may jsut drag even more debris into the passages of the case and contaminate it.
Old Aug 15, 2004 | 08:25 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Transmission shops use a pressure washer cabinet with a million little jets that shoot water in every possible direction, and the case sits on a turntable and spins slowly.... you could take it to the quarter car wash after teardown and accomplish the same thing, by removing every plug and cover, and sticking the wand in every hole. Use Gunk Engine Bright (diesel fuel in a spray can) or the store brand of the same thing, to loosen what's on the outside, while wahing it. Don't do the valve body that way though; soak it in lacquer thinner for a couple of days, slosh it around every now and then, then let it dry. I don't recommend disassembling it.
gta892000
Aug 11, 2019 11:16 AM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
sahlomonic
Sep 20, 2015 07:15 PM
timonator
Sep 17, 2015 06:57 PM
89fast5oh
Sep 8, 2015 09:55 AM
