Shifting problems
Old Aug 16, 2004 | 04:44 AM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
Shifting problems
Hey guys. I'm at my wits end with my transmission. First off I have a 700R4, B&M mega shifter, Transgo shiftkit stage 2, and a corvette servo. I installed the shifter two years ago. No problems there. Now the shift kit and servo were installed last year. The transmission shifts fine under part throttle. But when I go to WOT and manually shift it won't shift untill 5500. I've been told this is due to too high of a line pressure. I've reading the archives and everone says to just change the springs in the governer. But Wouldn't that defeat the perpose of shifting the tranny on my own? I've also adjusted the TV cable. Before I did this the transmission wouldn't shift manually even at part throttle now it does.
If someone could shed some light on this for me. Maybe point me in the right direction.
Oh by the way. When I adjusted the TV cable I only heard two clicks. Is this right?
Thanks guys :hail:
Old Aug 16, 2004 | 06:46 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Re: Shifting problems
What do you mean? You want to push it past 5500? Or you want it to shift before 5500?
Either way IMO (and I have been wrong before) I would say it is the governer you want to look at.
Old Aug 16, 2004 | 04:10 PM
Engine: 350 L98
Before 5500. If I adjust the governor will I be able to shift at any RPM I want?
Old Aug 17, 2004 | 12:00 AM
Engine: 350 L98
I talked to transgo today. They told me it was the governor. So I then phone around looking for a recalibration kit for the governor. www.700raptor.com sells them. They sell a superior unit. Lets hope this works.
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
