New converter not locking up?
Old Aug 17, 2004 | 10:14 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Ok guys, I just installed a built up 700R4 with a 9" Converter (approx. 3000stall) on my car. The kid who used to own it said its a lockup converter and it worked on his car.
Now on my stock 700R4, when I took off the pan, there were a bunch of wires and electrical connections. On this new tranny, I see none?!? Does this mean it doesn't have lockup???
PS the connector is plugged in on my tranny from the outside, I just dont understand how it would work if theres no wires inside my pan.
Old Aug 17, 2004 | 10:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yeah if you don't have any wiring it probably isn't going to lock up. Is the solenoid installed?
Old Aug 17, 2004 | 10:32 PM
Not sure exactly where the solenoid is located. Does anybody have pics???
The terminals from the plug don't even have wires coming off of them, I dont understand how the lockup could have worked without these wires in there. Maybe he was BS'ing me??
Also, would it be fine for me to do trips on the highway with a tranny cooler installed, even without the lockup?
Old Aug 17, 2004 | 10:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Normally it would look something like this:
<img src="http://www3.telus.net/~crussel/tcc_wiring.gif" width=100%>
Do you know what year the transmission is?
Old Aug 17, 2004 | 10:59 PM
I am going to get more specs on the tranny before I give you guys anymore headaches, I willl try to get intouch with him tomorrow and talk to the person who built it.
That connection that says "A B C D" is the bottom of the connector plug right? On my new tranny, there are no wires coming off of that.
Old Aug 17, 2004 | 11:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the connector plug. If your valvebody is earlier than 1989, then it is possible that the TCC lockup isn't electrically controlled, if it has a governor valve installed.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
scottmoyer
Sep 7, 2015 07:06 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
