what gears for 9 bolt??????????
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
How do I find out what gears I have in my 9 bolt, no tag on cover? Any help would be great.
Engine: TPI 305
yep
I have an 89 firebird formula WS6, with T-5, and 9bolt. The car was damaged before I bought it. The drivers side axle shaft is bent and I couldn't find a replacement. so I put in a 10 bolt, and am parting out the posi disc braked 9bolt. Any one need b parts?
Engine: TPI 305
Can I count the teeth of the gears to figure out wich ones I have. There has got to be some way to figure this out. I'm selling this setup, so I need to find out wich ones I have. Any help would be great.
Car: `86 SS / `87 SS
Re: ?????????????
Re: what gears for 9 bolt??????????
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
I agree that changing the gears is unlikely, but changing the whole rear is a very very common practice. I.e. the 3.70 posi/disc 9-bolt in the back of my '91 RS. Who knows what was done before he got the car?
Pull the cover and count.....it's the only way to really be sure.
Car: 4
Engine: 6
Transmission: 5
The issue is not what came in the car; that's not necessarily the same thing as what's in the car now.
Sooner or later somebody's going to ask him for his gears. And I can guarantee that if he tells them it has 3.45s and just pulls them and ships them, and they turn out to be 2.77s (because somebody "upgraded" to a 350 rear end somewhere along the line) after the parts arrive, there's going to be a real unhappy buyer out there.
Much wiser to go ahead and look, and assume nothing.
Engine: TPI 305
Original rear
It's the original rear end. I'm the third owner. The car is an 89 Firebird Formnula with a TPI 305, T-5, 9 bolt posi, with pbr disk brakes. It was originaly a Canadian car. Thanks for the info, I'm going to count teeth in the morning. And yes I'm parting out my 9 bolt.
Car: 4
Engine: 6
Transmission: 5
I'm the third owner
It's still important to count the teeth, to avoid screwing over somebody that buys the stuff.
Engine: TPI 305
Well
I checked the side of the ring gear and it say's 3.27, and I also counted the ring gear teeth at 36, and the pinion gear teeth at 11, and came up with 3.27. I am the third registered owner. The father of the family I bought it from was 1st owner, his son was 2nd owner, my father in law was 3rd owner, and I'm the fourth. There has nevewr been any rear end work done to the car, other than my swapping out the 9 bolt for a 10 bolt, cause I can't find parts.
hectre13
Dec 11, 2023 08:14 AM
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
