Tranny Strangeness?
Old Sep 13, 2004 | 10:01 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Tranny Strangeness?
Lately, the Firebird has been shifting strangely.
What happens is that when you jump on the throttle at around 45 MPH, it drops down a gear and accels upward through it (2nd?) and then before it goes into the next gear it feels like there is a hesitation, followed by a slight increase in RPM's prior to actually dropping into the next gear. There is no jekring or anything like that but it's clearly not a normal shift flow.
What is that? Should I be worried?
Trans was serviced at the begining of this year.
Old Sep 14, 2004 | 07:41 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Sounds like the 2-3 flare-up. Make sure your TV cable is adjusted properly (and that your throttle valve spring isn't worn out causing the cable to seem to be properly adjusted).
If that all checks out, you might consider upgrading to a corvette or better 2-4 servo (the one in the side of the case)..
Old Sep 14, 2004 | 10:57 AM
Cadillac's Avatar
OK... there is a name for it.
I found this on the web concerning TV cable adjustment:
http://purplesagetradingpost.com/sum...o/700R4p1.html
That's a start. Thanks TG88.
Old Sep 14, 2004 | 11:24 AM
thirdgen88's Avatar
Car: 1995 Corvette
Here is another article (EXCELLENT Piece!) that explains everything you need to know about the throttle valve systems in 200-4R and 700-R4/4L60 transmissions (and the potential problems):
Bowtie Overdrives: TV System 101
These guys also make AWESOME kits for setting up the TV system on aftermarket setups (edelbrock/holley/whatever). Oh, and you can also buy a line pressure gauge (essential for ensuring your tv cable is not just adjusted properly, but WORKING properly) for like $30 through them..
Old Sep 14, 2004 | 12:54 PM
Cadillac's Avatar
Indeed awesome.
Cracks me up how clean the pictures show the components of the car. Mine's a horrible mess in comparison.
Thanks again.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
BWilcox
Sep 20, 2015 12:19 PM
