Help fast shifting 700 r4
Old Sep 14, 2004 | 07:38 PM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
I had my tranny rebuilt in my 85 iroc. It has a trans go shift kit, corvette servo and a 2800 lockup stall. It shifts too fast if i floor it it will spin the tires in first shift at 4500 rpm into second second about 4000 3rd about 3500 then right away into 4th at about 3200. Trans guy said it was normal and it was shifting fine. It doesn't even spin the tires going into second unless i run it in drive. Getting sick of manually shifting it and I would like to use the full potential of this motor. See mods below. Thanks for any replies!!!
Old Sep 14, 2004 | 07:40 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
have you tried readjusting the tv cable??
Old Sep 15, 2004 | 06:14 PM
maroguy1's Avatar
oh yes many times
Old Sep 15, 2004 | 06:50 PM
nsimmons's Avatar
tv controls part throttle shifts, you need to change the govenor weights
Old Sep 15, 2004 | 09:00 PM
maroguy1's Avatar
How do I go about doing this. Can I buy them and change them while it is in the car?? Or is this a trans shop item??
Old Sep 15, 2004 | 09:49 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
its is very easy to change the govener... there is a cover that pops off the the drivers side of the tranny near the back and the govener just pulls out and you can slide a new one in
Old Sep 15, 2004 | 10:05 PM
ThommyDee's86Z's Avatar
Car: 86 Z28 w/ T Tops
Engine: 305 SB w/ Performer intake 3701
Transmission: 700 R4
Axle/Gears: stock
hardest part is putting cover back on while not denting or disfigureing it.
Old Sep 15, 2004 | 11:54 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
So this means once I do a bit of engine work and I'm going to have power all the way to 6k, I can change my WOT shift point just by swapping out a governor weight, with no need to drop the trans?!
Old Sep 16, 2004 | 02:39 AM
nsimmons's Avatar
yup
Old Sep 16, 2004 | 05:20 PM
maroguy1's Avatar
where can i find the governer and weights?? Is this a jebs or summit thing??
Old Sep 16, 2004 | 05:42 PM
nsimmons's Avatar
http://store.summitracing.com/partde...tt=bmm%2D20248
Old Sep 17, 2004 | 04:07 PM
maroguy1's Avatar
Thanks guys!!!!!!!!!!!
armac
Sep 29, 2015 07:06 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
tonys91rs
Sep 2, 2015 07:07 PM
