Strange Vibration...Need Input
Old Sep 15, 2004 | 12:26 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I have had this strange vibration ever since I bought this car last year. While I'm cruising in 5th gear between say 47 and 53 MPH I get this strange vibration that only occurs with my foot on accelerator. I can cruise in that speed range with my foot off the accelerator and it will be fine, but as soon as I apply any pressure to give it gas the vibration occurs. It feels like its comming from the rear and occurs in a rhythm and I don't know if it has to do with the transmission, driveshaft, or differential?? Any suggestions???
Old Sep 16, 2004 | 10:41 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
I GIVE UP ON THIS BOARD!!!
Old Sep 16, 2004 | 11:06 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Maybe you stumped them....
Ever done any problem solving? Replace bits one at a time and see if it stops...
Start with the easy stuff. see if you can't borrow/buy a cheap driftshaft and replace it and see if it changes. You could eliminate that.
Jack up the rear end, rotate the rear end, Check for looseness, sounds.
I'm not a mechanic..., had a funny squeak, that's what I did..., still there though, but the replacement driftshaft had a U-joint in way better shape. I kinda settled for it being the brakes, and it seems to have gone away.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
cheesehomer
Dec 31, 2015 08:48 AM
Linson
Oct 1, 2015 09:50 PM
BWilcox
Sep 20, 2015 12:19 PM
