700r4 cable connection to tb
Old Sep 15, 2004 | 06:04 PM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
the little green thing that connects the tv cable to the trotlle body broke kinda... is there anyway to replace that without getting a new cable...
btw its a 91 3.1
thanks...
Old Sep 15, 2004 | 07:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not really, changing the cable isn't all that much of a chore anyway. Don't drive the car with it broken.
Old Sep 15, 2004 | 09:08 PM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
im not driving with it broken, but i have to be able to drive so i connected it with a wire hange peice..., works, shifts right and everything so as long as the metal on the hanger doesnt streech then it should work right, right?
And obviosly, this is my highest priority at the moment, but it will be a while (2 weeks until i start job) until i get some money so this will have to do. But i have no special tools or anything. so will this be something i will be able to do by myself without any prior knowledge.
And last question, ive seen the cable for 25$ at bowtieoverdrives.com but is this a part i would be able to buy at autozone or pepboys?
Thanks much.
Old Sep 15, 2004 | 11:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm not sure what you mean. Can you post a picture? You should be able to get the cable at any parts store, or a dealer.
Old Sep 16, 2004 | 08:18 AM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
its the thing, the little green plastic peice that holds the cable to the throttle body.
ill try to post pic real quick... back in a few minuites
Old Sep 16, 2004 | 08:21 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
just buy a new one and replace it its not a good idea to drive it with a wire holding it on all thats going to happen is that wire is going to break or stretch and then your not going to have proper shifting or pressure in your transmission which leads to failure
Old Sep 16, 2004 | 08:32 AM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
i know... i am going to replace it, but at the moment i have no other choice but to rig it to work. and thats what im trying to ask now, how hard is it to do that???
in the picture, the green thing is supposed to be where the wire hanger is at.
and obviosly i will try to drive it as little as possible until i get it done...
Old Sep 16, 2004 | 08:42 AM
THEGENERAL's Avatar
Its not too hard of a swap on a v8 car but on a v6 its a little more difficult mainly because of where the tv cable bracket is and trying to get the cable in and out of the braket ..
Removing it at the transmission is simple just use a 10mm iirc socket and ratchet 1/4 in drive is preferable and loosen the bolt that holds the cable to the trasmission and then lift it up and remove the cable from the tab in the transmission then remove it up top and fish it out and fish the new one into place and reverse the process then adjust the cable and your ready to go shouldnt take you too long to accomplish.
Old Sep 16, 2004 | 09:29 AM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
ok, well besides the little aggrivating parts about the install, would i still be able to complete it, with just driving up on a 5 inch ramp?
and what is this iirc???
thanks...
Old Sep 16, 2004 | 10:22 AM
THEGENERAL's Avatar
thanks...
the five inch ramp hmmm only if your really thin..lol..id jack it up and put it on stands if possible
and iirc = if i recall correctly
Old Sep 16, 2004 | 10:48 AM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
ok, ill jack it up then...
about the iirc, i was thinking it was a specific type of socket... so thats good news to me...
very last question...
when you say "socket and ratchet 1/4 in drive is preferable " do you mean put the tranny in drive?
THANKS MUCH!!!
Old Sep 16, 2004 | 11:37 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Read that as "quarter inch drive".
Old Sep 16, 2004 | 12:01 PM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
ohh, ok sorry bout that then, guess im not up to the lingo yet...
THANKS for your help.
Old Sep 16, 2004 | 03:22 PM
THEGENERAL's Avatar
THANKS MUCH!!!
i should have spelled it out for ya sorry bout that .
good thing to ask if you dont understand thou ...
keep us posted . and if you have any more questions or problems be sure to post on here and let us know .
Old Sep 16, 2004 | 07:16 PM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
ok, thanks for your help and generosity.
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
