Transgo shift kit
Old Sep 19, 2004 | 07:56 PM
Incoming's Avatar
Car: 1986 Firebird T/A Streetracer
Engine: V8 350TPI
Transmission: Modified 700R4
Transgo shift kit
I have a 700r4 automatic transmission with a B&M console shifter.. a friend told me i could make my car into a manual but i didnt wanna have to go through with cuttin out my floor board and installing a clutch.. with the transgo shift kit i can shift up and down inbetween gears? 1st - 2nd - 3rd and 4th? otherwise i can keep it in automatic and it shifts gears faster? what benifits does this kit have on the car? and with the B&M can i shift it manually if i want?
thanks westley
Old Sep 20, 2004 | 11:31 AM
Incoming's Avatar
Engine: V8 350TPI
ok i used the
and read up on the shiftkit is this the kit i want???
http://www.racenet.net/drivetrn/transgo.php
for the 700r4
Old Sep 21, 2004 | 06:59 AM
rleprechaun's Avatar
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
The full Trans-go shift kit has the option of leaving your valve body full auto or auto/manual. It will tell you in the installation instructions how to do it for each. I did mine manual/auto and it works great. Realize if you are going to get the full bennifit out of this kit you will need to drop the trans to install the new selvo. Read and study the instructions and watch the video before you start. Then have the instructions with you as you go one step at a time.
Old Sep 21, 2004 | 08:16 PM
Incoming's Avatar
Engine: V8 350TPI
how long would you say it takes to drop the transmission? on a scale of 1-10
1 being easy 10 being advanced how would u rate it.
Old Sep 21, 2004 | 10:54 PM
Pro Built Automatics's Avatar
There is no need to drop the transmission to install the Corvette servo. Everything can be done from the bottom. If you want this kit to give you smooth shifts at light throttle, & firm shifts at WOT, then go to http://www.700r4l60e.com/store/custo...&cat=28&page=1 this will give you everything you need. If I can be of help, let me know?
Old Sep 22, 2004 | 01:27 AM
Car: 1987 TransAm
You do have to tilt the transmissoin downward to install install the servo. You do not have to completely remove the trans. I would rate this kit a 4. It would be an even smaller number, but you can't make a mistake in the valve body.
Old Sep 22, 2004 | 10:16 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Question: The Pro-built website says that the referenced Transgo kit is recommended for 1988 and up 700-R4s. Incoming has a 1986. Is this a concern? Was thinking about getting the same kit for my 87?
Old Sep 22, 2004 | 06:26 PM
Car: 1987 TransAm
I installed my shift kit on my early 1987 Firebird with no problems. I would not know about a 1986.
Old Sep 22, 2004 | 06:29 PM
naf's Avatar
naf
Did you get the kit from Pro-built?
Old Sep 22, 2004 | 07:03 PM
The kit will work on all years, but I have had problems with the 1987's with aux. valve body using the Performance Shift kit.
Old Sep 22, 2004 | 07:22 PM
naf's Avatar
naf
When installing your kit in an 87 is there something we should look out for or any precautions to take?
Old Sep 22, 2004 | 07:33 PM
The 1987 is a combination of early valve body with late internals. For some reason I & others that do these units have had problems on about 50% of the time. I have not been able to solve them, so I do not use these as a start for the Performance buildups. For HD use (modifying the The Trans-Go Shift kit & not using the Performance Shift kit) I have no problems.
Old Sep 22, 2004 | 08:03 PM
naf's Avatar
naf
Durability is important, so you would recommend the heavy duty transgo kit as the best performance alternative for an 87 700 R4?
Old Sep 22, 2004 | 08:06 PM
Car: 1987 TransAm
I got my shift kit from Summit or Jeg's. Sorry, don't remember which one.
Old Sep 23, 2004 | 02:44 AM
Yes, and I carry these.
Old May 11, 2005 | 07:20 PM
xdominationx's Avatar
Car: 85 trans am tpi
Engine: stock 305
Transmission: stock
i have an 85 700r4 what shift kit should i use?
Old May 15, 2005 | 03:30 AM
The HD kit.
Old May 5, 2019 | 12:59 PM
Rockstarv8's Avatar
Re: Transgo shift kit
I have a 700r4 on a 85 z28 305, I just added a transgo shift kit and a 2/4 servo, my shifts seem late, I tried putting a crimp fishing weight to adjust the Tv cable still seams late, any ideas? Also with a shift kit does that mean I can shift with my automatic transmission
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
