Torque Converter Shorter than stock
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I got a used rebuilt tranny for my 305 to 350 swap. I thought that I was all done intill the tranny did not work. I ended up finding the problem, the TC that came with the tranny was about 1/2 inch shorter that stock, so when bolted to the flex plate it was pulled out a bit and disingaged it from the tranny oil pump. I am in the prosses of getting longer bolts and using washers to space it out. Is this a good idea? I have already have it most the way done but I need one more washer or so on each bolt.
Kevin
Kevin
Engine: L98 350 TPI
Originally posted by chris718
also verify that thew convertor to crank pilot is still engaged or youll break the pump.
Kevin
Car: `86 SS / `87 SS
Originally posted by gearhead0384
What do you mean by that exactly?
Kevin
Kevin
Engine: L98 350 TPI
So the crank piolt is the thing in the middle that fits in to the center of the flexplate?
Kevin
Kevin
Engine: L98 350 TPI
Really. That is what happened then. How can that break the pump though?
Kevin
Kevin
Kevin
Kevin
Dialed_In
Aug 20, 2015 01:45 PM
