Borg Warner 9-bolt rear end
Old Sep 29, 2004 | 01:05 AM
chomp's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
I know a guy that is selling a Borg Warner 9-bolt rear end with 3.27 gears, posi, and a disc brake setup. It has about 8000 miles on it after a rebuild and was used on an 89RS.
I can get it for under $400 because he's parting out his car.
I know next to nothing about rear ends as far as quality. Is this a good rear end for a 92RS 305TBI car? I might put in an LT1 so will this rear end hold up?
Also, is changing this rear end from stock extremely difficult or is it a day job?
Lastly, am I getting a good deal on this? thanks in advance
Old Sep 29, 2004 | 05:45 AM
ede's Avatar
ede
9 bolt is stock rear and would bolt right in. not sure i'd pay 400 for one but it doesn't sound bad.
Old Sep 29, 2004 | 02:01 PM
chomp's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
Well it's good to know it'll be a fairly easy install.
Any other opinons about this ?
Old Sep 29, 2004 | 02:06 PM
arlockstedt's Avatar
Car: 89 Firebird Formula 350 WS6
9 bolts are BAD @ss! very strong...just hard to find parts for or expensive to rebuilt. WHen TA performance gets their act together and get the rear end girdle made......the 9-bolt would be even more solid. As an owner of a 9-bolt...... i LOVE it:rockon:
Old Sep 29, 2004 | 08:43 PM
chomp's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
Okay so it's much better than the stock one that I have?
Think it's a good deal? He's had it for sale for 2 months so I can probably get it for $300
Old Sep 29, 2004 | 08:47 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
While you're at it get the speedo gear and VSS out of the transmission, you'll need it if you want your speedometer to work right.
Old Sep 29, 2004 | 09:20 PM
sounds like a deal to me...but yeah get those other parts.....
Old Sep 30, 2004 | 03:50 AM
chomp's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
Can you elaborate on those other parts I'll need to get? What's involved in that?
Old Sep 30, 2004 | 10:55 AM
like Trickster said "While you're at it get the speedo gear and VSS out of the transmission, you'll need it if you want your speedometer to work right."
Hope that helps.
:lala:
Old Sep 30, 2004 | 12:28 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You will need those to calibrate your speedometer to the transmission so that your speedometer will accurately read your speed. Otherwise your speedometer might be reading 55 and the cop pulls you over and says you were doing 75. Here is a picture of it. Also make sure that your tires are also of a size that matches your new rear end or it will also throw the speedo off.
Old Oct 6, 2004 | 02:02 AM
chomp's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
So what do I do to calibrate it?
Is there a walk though somewhere on this?
Old Oct 6, 2004 | 02:48 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Do you have disk or drum brakes now?If you have drum brakes now then you'll need to buy a new proportioning valve.You can only get them at the dealer.I just did the swap and the new valve cost 108 bucks.
Old Oct 6, 2004 | 11:22 AM
chomp's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
Yes I do have drum brakes now, and my friend mentioned something about that valve. Are you sure you can only get it at the dealer? If you tell me what exactly it's called I can see if ebay has it.
Do you happen to know anything about the speedo gears and getting all that calibrated?
Old Oct 6, 2004 | 11:29 AM
ljnowell's Avatar
go to the junyard and find the valve, not too hard to get.[
Old Oct 6, 2004 | 05:23 PM
Peter82Z28's Avatar
Car: Z28 / 1982
Engine: 305 (LG4) Stock
Transmission: TH350
Check here...
http://www.tciauto.com/tech_info/speedo_gears.htm
Old Oct 6, 2004 | 07:06 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Well you run the chance of getting a proportioning valve that's stripped or something at a junkyard.You don't want to skimp on something like brakes.It's only 108 bucks.I forgot,you also have to switch the master cylinder.The piston bore is bigger for disks.I think for drums it's like.75 and disks are 1.00.You'll be happy with the swap.It only took me a day and a half to do by myself.
Old Oct 6, 2004 | 07:14 PM
ljnowell's Avatar
Dont buy it if its stripped. Its either good or not. There is nothing wrong with the valve from a junkyard.
Old Oct 6, 2004 | 07:52 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
You can't just look at it and tell if it's stripped all the time.Why take the chance?
Old Oct 6, 2004 | 08:05 PM
ljnowell's Avatar
Whatever. Thats your preference to not buy used parts. If it were me, I wouldnt spend a 100 dollars on it. I would go to the junkyard. You could buy 20 of them for 100 dollars. I am sure they would be good. And how can you not tell if something is stripped? If you take the lines off, you can re-tighten them to check? Its a matter of preference, and I prefer to spen my $$ on parts that go fast. Its not an issue of safety. Used parts are just as good.
Old Oct 6, 2004 | 11:08 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I agree that some parts from the junkyard are a good deal but if he is going to spend the money on the rear end and take the time to swap it then why not do it the right way and just put in a new valve?It is a preference and you'd think that with something like brakes you wouldn't want to just stick in a junkyard piece.If He was buying some interior pieces or something then I would say go to the junkyard.When I did my swap the valve stripped but the line felt like it was in all the way and you couln't see any of the threads being bad but it wa still stripped.Hey chomp,do what you feel is best for your budget and safety.It's your car and your money.I hope everything turns out.Good luck.
hectre13
Dec 11, 2023 08:14 AM
theshackle
Sep 17, 2020 08:26 AM
fasteddi
Sep 2, 2015 10:29 AM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
