Leaking 700R4
Old Sep 29, 2004 | 07:17 AM
87camz28's Avatar
Car: 1987 Camaro Z28
Engine: 5.7L, L98 slightly modified
Leaking 700R4
I have a 1987 Z28 with a new reman 700R4 tranny. After the shop that put the trans in returned it to me it was leaking. I took it back to them and they found a cracked housing on the TV cable that was causing the leak. After picking it up and letting it sit for a week, there was another puddle of trans fluid under the car. When I checked the fluid it was up to the full mark after the car warmed up. I took the car back to the shop a second time and left it there for a week. They put it on the lift and said that they couldn't find a leak. The mechanic said he put more fluid in it because it was just below the full mark on the dip stick.
I got it back home last night and this morning there was another puddle of trans fluid under the car, but the fluid was up to the full mark on the dip stick. Is there any kind of vent hole that will leak oil out on a 700R4 if it is over filled?
Old Sep 29, 2004 | 11:28 AM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
That stinks! but it could be leaking from anywhere. :shrug: Have you had a chance to crawl under there and see about where it might be coming from?
Old Sep 30, 2004 | 07:32 AM
87camz28's Avatar
I haven't had time to get under there yet. I think there is a vent hole somewhere that oil will leak out of if the trans is over filled but I am not sure. The level doesn't seem to be moving off the full mark when the car is warm though . I am going to try and get under there this weekend and check it out.
Old Sep 30, 2004 | 08:36 AM
-ZERO-'s Avatar
Engine: 305 H.O.
That vent hole that your referring to is on the top of the tranny. hope that helps!
Old Sep 30, 2004 | 10:06 AM
87camz28's Avatar
Yeah, I hope that's where it is coming from and it is as simple as an over filled transmission. Thanks for the help.
Old Sep 30, 2004 | 10:13 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
look at where the puddle is located in relation to the tranny. Is it collecting torward the rear, middle, or front??
Old Sep 30, 2004 | 12:52 PM
87camz28's Avatar
The leak is centered directly under the middle of the pan, but it is not leaking from the pan.
Old Sep 30, 2004 | 01:53 PM
-ZERO-'s Avatar
Engine: 305 H.O.
Do this. take your flywheel cover off and see if anything is leaking from the seal were the torque converter goes into the tranny or from the outer pump seal.
Old Sep 30, 2004 | 02:58 PM
87camz28's Avatar
That's what I planned to do this weekend. Hopefully it is nothing major.
Old Sep 30, 2004 | 03:23 PM
-ZERO-'s Avatar
Engine: 305 H.O.
lets us know what ya find!
Old Oct 1, 2004 | 12:28 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Is the tranny clean or dirty. If it's dirty and you still can't find the leak the 2nd time under there clean it real good with some brake clean and run the car for a day or 2 and check for a leak again
Old Oct 1, 2004 | 07:12 AM
87camz28's Avatar
The tranny is a new reman so it is still pretty clean. Thanks for the advice, I'll try that this weekend.
plm99
Southern California Area
Nov 16, 2015 05:21 PM
BWilcox
Sep 20, 2015 12:19 PM
84redta
Sep 19, 2015 09:58 AM
bubbaz28
Sep 18, 2015 02:09 PM
bamaboy0323
Sep 12, 2015 07:14 PM
